Originally Posted by
antonfuntek
Hello Ironspyder,
I’m reaching out to you because I have the same machine (KL-6090) purchased from the same place. They were supposed to have the machine set up out of the box, but my z is not moving in the negative direction/cut into the wood when the program is run. I can move the machine via the keyboard with no problems at all. The guys at AT are telling me the machine is configured correctly and it must be the g-code. I’ve run code from Aspire, both in .txt and .tap formats and I’ve run g-code from the wizards within Mach 3 and the roadrunner test g-code included with Mach 3, and they all do the same thing, the z will not cut into the wood. My question is, what problems did you have when you first ran your machine? Any help would be greatly appreciated.
Thanks,
Anton
