603,326 active members*
3,597 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 6M-B controller shut down while running, now stuck in IL mode
    Jun 2010
    Hello all;
    Newbie here. I registered hoping to find some answers. Here's the story...
    I'd just edited a program on my CNC today (older Mori), exited edit mode and started running the program, when all of a sudden I heard a soft but clearly audible "click" from the controller, and then the screen went completely blank.
    The spindle was still turning, but I couldn't stop it either with the STP button, reset button, or even the E-stop. I turned off the main switch, waited about a minute, then turned it back on.
    Controller had normal stuff on it (FIFO Not Ready, etc). I turned the controller on, it flashed some characters on the screen, and went into IP MODE. Six choices there...forget what they all were just now.
    I can't exit IP MODE with any button on the console, even Reset. Nor can I select any of the 6 choices (press key #2 and hit "input" key...nothing happens....ditto for remaining 5 items).
    Called Fanuc and they said probably a board on the main board. A Fanuc tech will be out in a few days.
    Can anyone explain to me what may've happened to my controller? And, is there any way to exit IP MODE that I haven't tried?
    Thanks to all for reading and answering.
    Harry
    May 2009
    181
    bmu took a crap or the mainboard.. measure all voltages on main board 5 15 -15 24..
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. Fanuc 6MB stuck in jog mode
    By Andy Fritz in forum Fanuc
    Last Post: 02-26-2010, 10:33 PM
  3. GECKO G540 - Stuck in "FAULT" mode.. HELP!?!
    By CNC74 in forum Benchtop Machines
    Last Post: 02-06-2010, 09:37 AM
  4. running dnc mode on hardinge
    By marcojr in forum Bridgeport / Hardinge Mills
    Last Post: 09-19-2007, 07:26 PM
  5. Phase mode without controller
    By Alex101 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-12-2007, 11:53 AM
