Hi
I have a Yamazaki Power Center V-7.5 with a Fanuc 6M(B) controller that has lost it's Y home position. It runs to the Ref Point switches and goes into creep mode for the last 30mm ish (not sure of the true run distance) but has forgotten when to stop creeping and runs into the hard stops and trips the drive motors out.
On our Takumi V-11A with Fanuc 0-M Control, when it did the same trick we could press <P> and <CAN> and get it to refind it's "home" position, but I have failed to find the same key combination to do the same with the 6M.
Any suggestions?
Regards
Richard
