587,303 active members*
3,851 visitors online*
Results 1 to 5 of 5
    May 2004
    402
    6M Main board suffix numbers
    What is the difference between an A16B-1000-0030 / 05C and an A16B-1000-0030 / 06C
    Presumably the 06C is a later release but is it functionally much different? Reason that I ask is that I've acquired an 06C version as a potential spare for my (currently working !!) 05C version.
    Andrew Mawson
    East Sussex, UK
    Apr 2009
    1379
    I don't know the specific difference, but you can supposedly always replace a board with a higher revision.
    Jan 2009
    117
    The functionality is exactly the same. Fanuc might have done some minor "bug fixes" or changed some chip sets to "newer" versions for that time period.
    HRH Reply is exactly correct. The 5C and 6C is the version changes. Function wise both are Same no need to worry about the Version for Replacement.
    Aug 2008
    406
    You can allways change to a higher revision number you can not go backwards to a lower one......!
  1. Fanuc 18t-b main board plug in cards
    By amtekinc in forum Fanuc
    Last Post: 03-23-2011, 07:15 AM
  2. Milltronics Centurion 4 main board feedback
    By Captain Midnigh in forum Milltronics
    Last Post: 10-31-2009, 10:52 PM
  3. MAIN BOARD POWER UNIT
    By gabedrummin in forum Fanuc
    Last Post: 09-27-2009, 09:37 AM
  4. main haas board
    By daleman in forum Haas Mills
    Last Post: 03-17-2007, 12:58 AM
  5. Wtb: Autocon Delta 20 Main Board
    By 2COOL585 in forum Uncategorised MetalWorking Machines
    Last Post: 09-21-2005, 03:16 AM
