587,418 active members*
3,560 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 6T-B spindle problem Over current/field loss
    Jun 2007
    61
    I had been getting an occasional circuit breaker pop that turned constant, I changed the buck/boost taps to 275V input which stopped the breaker and let me see that the OC/FL led was lit. After a lot of probing and poking I checked the field at the motor and found it to be about 3.4 Ohms, the armature checks at 1.3 Ohms. Is this usual? If not what should the field be? Any help appreiciated. Ed.
    May 2009
    181
    i would call fanuc on this one dc spindles are a ***** to work on..
  1. Low Current interface, High Current Motor?
    By Clackvalve in forum CNC Machine Related Electronics
    Last Post: 05-13-2010, 06:42 PM
  2. X3 loss of spindle speed control
    By binfordw in forum Benchtop Machines
    Last Post: 03-09-2010, 07:42 PM
  3. E-stop, spindle kill and current set resistors!!
    By jestah in forum DIY CNC Router Table Machines
    Last Post: 07-03-2009, 10:37 AM
  4. Wanted Lathe, oil field and hollow spindle
    By nemco in forum Want To Buy...Need help!
    Last Post: 09-14-2008, 04:33 PM
  5. Field Loss
    By bbrreid in forum Servo Motors / Drives
    Last Post: 09-05-2007, 12:00 AM
