Below is his local ad-posting and emails i received back followed by pictures.
(pictures dont show a lot, but maybe some one could tell me if this would be a decent deal and if the rust would be a monster issue.. bead blast?) I plan on going to take a look at it sunday! I will try and get more photos!. Possibly be a sweet deal with some custom work it could add up to a really nice machine if i could get a 4" z axis out of it (but as long as i can fit a .063" sheet of aluminum-.25" sheet i will be golden!!)
Thanks guys!
"I have a 6' * 12' plotter that came from Boeing. I was planning to raise the rails about 4" and add a Z axis to this machine to turn it into a CNC Router. Unfortunately I have more projects than time and this one is taking up too much space. It has precision rack and pinion rails which would cost you more than the price of this whole machine."
"Here are some pictures of the biggest problem with this unit. It has been stored under cover the entire time I owned it but it was not in a heated space all of the time and there is some rust on the rails which will need to be dealt with. To answer your other questions.
1. What material is the table and machine made out of?
I am not exactly sure but some sort of plastic or fiberglass, it is covered with 1000's of small holes that were used for vacuum to hold down the vinyl. That is the table, of course. The frame is steel and very rigid. If you know anything about vinyl plotters, the concept is to cut through the vinyl and leave the paper backing, this is very tight tolerances.
2. How many rails are there, it looks like the table is in halfs.
The rails themselves are about 2 feet long and numbered to match, they are all mounted on a scraped aluminum rail for flatness. The table is in 2 parts and the end piece is laying on top of the other. This machine was 40' - 60' long when it was in use but I only have the 2 tables as I did not see any reason for the others, my shop is not that big.
3.does it come with any motors, electronics?
All of the drive motors are there. There is an electronics cabinet that came with it and you are more than welcome to it also. As for anything that will work out of the box, don't count on it. My plan was to install servo drives and Mach software. I have one other machine running on Mach now and one more in the works. Great software!
4. How many axis's does it have x,y,z?
It has 2 driven axis's and a plate where the plotter knife used to be mounted. The Y axis ball screw has a huge pitch on it and I was planning on having to replace it but with the torque needed for plasma that may not be necessary. The rust on the screw might be the only concern. Maybe it was someone else that wanted to build a plasma table, I can't remember."
update:
"I can get you the exact dimension tomorrow but I am sure the Z axis is in excess of 2".
"The motors are attached and they are servos. Servos are what I have on my other machines and I have had no problems. I assume that you are talking about connecting the two tables for your third question. It is lined up with guide pins and the bolted together. The pinion rails are numbered to mate in the center. I am 95% sure that the rails I have are numbered to match"
Update 2:
"I am not sure what they weigh but I can pick each piece independently with my Bobcat which is capable of about 4000#. My guess would be 3000# for the main unit and another 1000# for the extension. Because of the length of it I can not pick them up together."
So far its huge and heavy duty steel!! Thoughts opinions?!
