587,524 active members*
3,360 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > 7x10 ballscrew - mini lathe cnc conversion
Results 1 to 4 of 4
    Mar 2007
    15
    Can anyone recommend me ballscrew brands and model numbers for my 7x10 mini lathe (sieg c2) Z and X axes.
    I wonder how can anyone fit a ballscrew with ballnut under the the cross slide of such small size. Must be miniature ballscrew...
    Is there a site with similar cnc conversions, videos etc.
    Thanks in advance
    Sep 2008
    229
    Quote Originally Posted by tbilalis View Post
    Looking at the post date I guess I am a bit late with this, but see this thread.
    http://www.cnczone.com/forums/showth...t=63621&page=2
    Feb 2008
    ballscrew replacement
    there are 2 class of ball screw, c and h. C is low end with some backlash, H is much more precise. The differance in price is steep, usually 4-5 times the price, but you get what you pay for. A good alternative to a ballscrew for sonething this size is a multistart leadscrew (not acme threads) good quality screws will have a trapazodial design and are avaiable with anti-backlash nuts which is it's most basic forn 2 opposing nuts with a tensioner and spring. companies such as danaher automation, ezcnc, kerk, and nook are good sources. a great quality leadscrew will be muchmore cost effective than a ballscrew, less maintaince, and no chance of sending hundreds of bearings flying out the end of the ballnut. good quality lead screws are only about 10% less efficent than a ballscrew too.
    Mar 2009
    4
    i have almost finished my c2 lathe conversion
    hello everybody!
    this is my very first post.
    I´m working on a cnc conversion on a sieg c2 mini lathe for educational/training purposes
    I have mounted X ad Z ballscrews from homeshopcnc.com, servos and drives from IMservice, breakout board from probotix, and Im evaluating turbocnc that actualy I use in a huge pratt & withney jigborer, and EMC2.
    please coment, in few day I will publish some photos.
    greetings from México.
  1. HF 7x10 to 7x19 bed conversion
    By KOS in forum Mini Lathe
    Last Post: 12-09-2008, 06:05 PM
  2. Non breaking... gear for 7x10 mini-lathe?
    By jinu117 in forum Mini Lathe
    Last Post: 11-27-2006, 02:11 PM
  3. CNC mini-lathe conversion help needed.
    By minilatheman in forum Mini Lathe
    Last Post: 05-24-2005, 01:47 PM
  4. Mini lathe conversion
    By kdoney in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2004, 04:21 AM
  5. Mini-Mill Ballscrew conversion?
    By rustyolddo in forum Benchtop Machines
    Last Post: 07-29-2004, 04:22 PM
