587,941 active members*
3,194 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Jul 2005
    82
    8020 Aluminum Build
    I've started a new machine build using primarily 80/20 3030 and hiwin 15mm linear slides. Some of the pictures below are from about 2 months ago at the start, up until last night I think. Progress has been slow but picked up a little bit lately.
    The pictures below are of the gantry, I haven't even started the main table section, however I did just receive those in the mail yesterday. I hope to get working on that, but getting those 2 pieces together is going to be an undertaking as the gantry already weighs about 80 pounds I would guess, although i'm not an accurate scale so that's plus or minus 50% hehe.
    I'll post more as the build progresses.
    Ross
    Attached Thumbnails Attached Thumbnails sany0001.jpg   sany0002.jpg   sany0003.jpg   sany0006.jpg
    Dec 2007
    24
    Hi Ross
    I am also planning to make my CNC with 80/20. Your gantry design looks really interesting. Do you have any more pictures showing your progress since the other pictures you posted?
    Mike M.
    Jul 2005
    82
    Well i've made some good progress, today I finally got the gantry attached to the X Axis, also got the legs on. So far my main concern (not sure how to explain this) of the gantry twisting, like when the router is all the way on one side, and it has a lot of force on it, that's a twisting force. Initial tests showed that I couldn't even budge it, so i'm quite happy, and I haven't even done any re-inforcement yet.
    Not sure you can tell from the pictures, but much more re-inforcement will be done to the gantry connection area. There are hiwin 15mm rails on the underside of the X axis, the same ones that are visible on the gantry for the Y and Z axis.
    Surprisingly it slides with ease, the main gantry that is. I made sure everything was within very tight tolerances the whole time, and I guess it paid off. I can just push the gantry and it slides along and it's still extremly rigid.
    I plan on adding more cross members to the main table section as well, which should also increase strength of the table, and help avoid twisting as I discussed about near the middle of the table.
    Also, you may go "the damn thing is on wheels!", but I put those one because I want to be able to move it out for maintenance reasons easily, I plan on anchoring my machine into the concrete wall you see to the left of it, I'm pretty sure it's solid
    Ross
    Attached Thumbnails Attached Thumbnails sany0015.jpg   sany0017.jpg   sany0018.jpg
    Dec 2006
    277
    Hi Ross,
    Looks pretty good so far
    Bob
    Feb 2008
    263
    Ross, How large is your machine and how much did you spend on aluminum stuff?
    Jul 2005
    82
    The machine dimension specs are this:
    X: 49"
    Y: 25"
    Z: 5-6" (Not sure how it will turn out with the depth of the table board I use, plus fastening system..)
    X and Y are meant to be just above 2 foot by 4 foot working area.
    So far in aluminum extrusions, plus plates/t-nuts/misc 8020 stuff is around $1300. That doesn't include the stock aluminum I bought and made custom plates though, I made a bunch of 3" by 9" connector plates, some other plates as well. I would price all those at $200-$300, so i guess around $1500. I got all my aluminum extrusions from automation4less.com. Also I got my linear rails from them as well, I did NOT include any of those prices in what I mentioned above though.
    Ross
    Mar 2004
    761
    Read this link on how to prevent the twisting of the gantry. Post #51 is the Key illustration of the application.
    http://www.cnczone.com/forums/showth...racking&page=5
    Wayne Hill
    Sep 2003
    1475
    Smile
    Hey, Check out the clear plastic CNC on the side. Nice looking and pretty heavy duty. Have you donumented this? :rainfro:
    Looks like an example of build one to make one.
    Nice looking projects.
    Mar 2008
    17
    Smile Guides
    i was looking at these a few days ago.. and was wondering if there were bearings in the guides or does it slide on delrin or something like that.. thanks
    Jul 2005
    82
    Wayne, Thanks for that link, very interesting design. Simple yet effective. I'm hoping I won't have to utilize that, but if there is any twisting action i'll surely use that method to fix it.
    Mr.Chips, That's my old CNC machine, built originally from hobbycnc plans, if you notice that big piece of plexiglas is about the same shape as a standard hobbycnc plans. I also rebuilt the whole Z axis out of plexiglass, which was much different then the original. I'll try and post another picture of it later, and yes, I am using my old machine to help build the new machine
    minisoft, Not sure if that's a question of a statement, you can see the linear slides in the pictures, they are Hiwin slides. www.automation4less.com has more details, they are ball bearing based. My blocks have 2 scrappers on them to clean the slides before it moves over them, hope they are effective but only time will tell ehhe.
    Ross
    Sep 2003
    1475
    Smile
    Quote Originally Posted by klick0 View Post
    Ross
    That looks like bank teller type material. Have not seen anything like that in the DIY stores.
    Looking forward to pictures.
    Mar 2008
    17
    Guides
    Mr chips. sorry for not being clear.. i meant that i was looking at the linear guides the other day. but couldnt tell if they had actual bearings on the inside of the block or if it had the delrin or some other plastic slide. but i took a better look at the blocks and guides and found out they did have bearings.. so that was what i was asking .. if it had bearing..lol.. thanks for the reply..
    Sep 2003
    1475
    Quote Originally Posted by minisoft View Post
    Think you mean this for "Ross" the builder.
    Mar 2008
    17
    yes i did
    yes .. klick0 aka rose.. sorry about that
    Dec 2007
    24
    Hi Ross,
    The gantry looks pretty stout alright. Did you happen to run it through the 80/20 deflection calculator to see what it comes up with? Just by looking at it it looks like you could easily put a 3 HP+ router on the Z axis when it's ready and still be well within .001" deflection.
    Looks like it's going to be a really great machine when completed.
    Mike M.
    Mar 2008
    17
    build
    i built one somthing like his a month or so ago and i have a 3.25 hp on mine.. i just did a pcb today and looks like a $50000 machine did it... mine is all 80/20 also.. just little different then his.. im building a new one right now. just because im bored..lol.
  17. #17
    Jul 2005
    82
    Mike, Nah, I don't even know where an 80/20 deflection calculator is... Also i'm still doing more reinforcements, so hopefully it will be even more rigid after that.
    I've attached a pic of my old machine, you could see part of it in one of the other pictures. I plan to use the router it has, really my old machine can't really handle that, but I wanted a bigger router on it eheh.
    Tonight I was working on the main Z axis plate, I was threading a hole and broke off the threader/die thing. I can't figure out how to back those things out, luckily it isn't necessarily a required hole, so i'll just cover it up, and hope I don't need to use it. Regardless, the plate is getting closer, and I should receive the last few parts I need by next week for that, I still need to make other parts for this, but things are moving along which is good
    I did do some testing, I hooked up the Y axis, and tested my backlash. At first I thought I had about 2 hundredths of an inch in backlash, which I was devastated. I then realized that the clamp I had holding down my digital calipers was loose, and was moving back and forth, i tightened that down, and tested again. I came up with 1 thousandth of an inch or less, granted that's with no load, I did try to push on it back and forth and it didn't budge at all, so it's looking really freaking good. My old machine on the X axis had like 1/40th an inch of backlash... eheh, it was freaking horrible, so this machine is looking much better Can't wait to get the other axis on and tested. Granted the real test will be when it's hooked up to the computer, but these initial tests look very promising.
    Ross
  18. #18
    Mar 2008
    40
    8020 deflection calculator download here....
    Mike, Nah, I don't even know where an 80/20 deflection calculator is... Ross
    Here's what I found on the http://8020.net site, their "deflection calculator" download. Have fun!
    http://8020.net/Design-Tools-26.asp
    Sincerely,
    DIY-Guy "Becoming a bit more dangerous with each new piece of knowledge!"
    P.S. I have not downloaded this yet and do not currently know how to use it, but I would like to know how.
  19. #19
    Dec 2007
    24
    The deflection calculator is really easy to use. You just pick which 80/20 product you are testing from their drop down list, enter the distance of the unsupported span, in inches or milimeters, depending on which product it is, enter a figure for the weight which will be on the product (this can be a known quantity or a guesstimate) and click on the "Calculate Deflection" button. The program will then give you the deflection according to several senerios: 1. the weight is evenly distributed along the span; 2. the weight is centered in the middle of the span; 3. the product is standing on edge; 4. the product is laying flat.
    If you are still in the design phase of your machine you can use this program to jockey the parameters around and help you decide which products to use, e.g. 1530 or 1545, where you will need bracing, how many cross pieces you will need, etc. Very useful tool.
    The only thing is, when you're done you have your answers, if you're gonna use 80/20 brand! Who knows if it is the same for T-Slots, or any of the others.
    Mike M.
  20. #20
    Jul 2005
    82
    Ok, it's been a while since an update has occured, busy with work has slowed me down a bit but i've been trying to get the machine done. I am much further along now, the machine actually moves around on all axis, does so with great precision so far. The biggest challenge that was accomplished since last post is the electronics box, which isn't quite done, but I posted a picture, it's a task I dreaded and now most of the hard stuff is over with it, so i'm quite happy
    The only thing left to do is the limit switches, which i'm about 20% done with i'd say. I could run the machine with something, but I'm patient enough to wait till I get the limit switches done before running it. Granted I don't have a tabletop on it yet, but that's not much effort, I have all the parts needed to throw that on.
    Also with my new control board, I have some digital outputs that I could use to control whether or not the spindle is turned on, which would be nice. Really the main reason I want that is during an ESTOP it will turn it off, or I would assume it does. Also the machine is much larger, and i can't lean over to turn it on before hitting the Run button for the program, so it would help out for that as well. I have no intentions of doing RPM control though, as I just use a standard router anyway...
    Ross
    Attached Thumbnails Attached Thumbnails sany0024.jpg   sany0025.jpg   sany0026.jpg
Page 1 of 2 12
  1. 8020 BBR Router Build
    By ddbuster in forum DIY CNC Router Table Machines
    Last Post: 10-15-2017, 12:16 AM
  2. need to build a cnc router / mill for aluminum
    By axkiker in forum DIY CNC Router Table Machines
    Last Post: 07-30-2013, 07:36 AM
  3. First build - 8020 with servos or steppers
    By sandiegocadcam in forum DIY CNC Router Table Machines
    Last Post: 03-24-2008, 11:21 PM
  4. Discussion: Using aluminum tooling plate to build a bridge mill.
    By Deviant in forum Uncategorised MetalWorking Machines
    Last Post: 08-11-2006, 07:18 PM
  5. Cutting 8020
    By dneisler in forum DIY CNC Router Table Machines
    Last Post: 10-03-2005, 02:24 PM
