I'm planning to use 8020 3060 profile for a 8'x4' wood router, basically to cut plywood sheet into various panels for boat hulls, furniture, cabinets etc. Milling would be minimal, maybe the odd dado or hinge recess.
I'm going to start small 2'x2' and cheap, using shimmed 8020 slides on all axis etc. Although I would splurge for 4 Nema 34 drives.
Now I had the drive mech all clear in my head and now I've lost the supplier details!
Basically it was a belt drive that was designed to mate to the ends of an extrusion. So on one end was the drive, and pulley bolted into the exposed pipes and on the other was another pulley with a tensioner. The belt run from the slide along the top of the extrusion, around drive, through the extrusion to the other end, round the tensioner pulley and back to the slide, very KISS.
So can anyone Id the company for me?
