603,382 active members*
3,462 visitors online*
Results 1 to 8 of 8
    Jul 2005
    7
    8020 CNC Router
    The goal was to build a CNC router from 8020 aluminum extrusions. Ultimately the picture below shows where I ended up....
    This router was built 2 years ago. I've started transcribing my notes into a blog which is part Instructable, part ramblings of someone who spent too much time in the garage.
    DLS Projects: Part 1 - CNC Custom Router Intro
    Jul 2005
    7
    The base consists of 4 x 1030 8020 extrusions arranged to form a fully supported base. This design will have 2 lead screws on the X axis, one on either side. A slightly more expensive way to do this but it helps overall rigidity.
    I've added more detail to linear motion slection and the base assembly to the blog
    DLS Projects: Part 4 - Linear Motion
    DLS Projects: Part 5 - Router Base Assembly
    Jul 2005
    7
    Added detailed dimensional drawings for the bearing blocks, motor mounts, delrin nuts to the blog. The drawings don't meet any mechanical drawing standards but have enough detail for you to make your own parts.
    DLS Projects: Part 6 - X Axis
    The blog provides additional technical detail of the X-Axis parts and assembly.
    Let me know what you think.
    Dec 2010
    always fascinating reading someone else's build log
    (you might want to shuffle the order of the links on the right hand side top of your blog
    seems to go 1, 2, 4, 3, 5, 6)
    Jul 2005
    7
    Here's a practical application of the router. A switch mount for a custom pro street chopper I'm building
    Midnight Customs: Part 8 - Regulator and CNC Switch Mount
    Oct 2007
    269
    Nice build :cheers:
    Oct 2013
    Hi, do you have detailed info on your z axis?
    Jul 2005
    7
    I threw some pictures onto DLS Projects: Part 7 - Z Axis
  1. 8020 BBR Router Build
    By ddbuster in forum DIY CNC Router Table Machines
    Last Post: 10-15-2017, 12:16 AM
  2. 8020 Router 8' x 2' Rex 2.0
    By RedskinsJBS in forum CNC Wood Router Project Log
    Last Post: 08-29-2011, 08:19 PM
  3. Ahren's 8020 Router
    By ahren in forum CNC Wood Router Project Log
    Last Post: 09-24-2007, 04:10 AM
  4. 8020 cnc router table top
    By eloid in forum CNC Wood Router Project Log
    Last Post: 02-25-2007, 02:32 AM
  5. Results from using 8020 for a CNC router
    By WarrenW in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 01-06-2006, 03:17 AM
