603,340 active members*
4,011 visitors online*
Hybrid View
    Apr 2004
    38
    8mm watchmaker collet dimensions
    I am looking for the dimensions for the 8mm collets that are used in watchmakers lathes or the Sherline lathe. I have a project that I need to see if this collet will work. any information on where I can find this information would be great.
    Jim W
    Jun 2007
    5
    Sherline's site only states:
    Sherline WW collets that have a shank diameter of .312-.313". Other manufacturers make collets that vary in size up to .314-.315"
    The larger size is referred to as an 8mm collet....
  1. Moving Dimensions
    By Mastercam User in forum Mastercam
    Last Post: 11-16-2007, 01:50 AM
  2. C6 Lathe bed Dimensions
    By krazatchu in forum Syil Products
    Last Post: 06-06-2007, 09:03 AM
  3. RFQ: Estimate Needed On Small Steel Adapter WatchMaker?
    By mabmojo in forum Employment Opportunity
    Last Post: 12-26-2006, 08:34 PM
  4. TL2 Dimensions
    By AMCTony in forum Haas Mills
    Last Post: 11-22-2006, 06:57 PM
  5. Maxnc Dimensions??
    By RAMSSupport in forum Benchtop Machines
    Last Post: 12-05-2005, 04:12 AM
