9x20 leadscrew disengagement
john,
I have a 9x20 so here are your choices
1 you can pull down the handle on the quick change gear box to the down
position and this will stop the leadscrew from turning, but the some of the gears in the gear box will still rotate.
2 If you want to save ware and tare as I did, on those gears and stop them from turning when you dont need them you can build a reverse tumbler.
3 here are the plans to build reverse tumbler, you will need to make some bushings drill some holes in a 1/4 in steel or aluminum plate and cut the plate to fit the space and be sure you can measure very good.
http://groups.yahoo.com/group/9x20Lathe2/ join free look under files tumbler reverse modifications Good Luck Cap.
http://groups.yahoo.com/group/9x20Lathe/files/
Don't Give Up The Ship !!!
