603,954 active members*
3,182 visitors online*
    Sep 2011
    7
    9' x 5' cnc, need help about mechanical
    Hi all im from far east,
    soon i have plan build 9' x 5' cnc laser co2 machine gantry load is laser tube 4' long and power supply. i need help about choosing mechanical like belt or ball screw, linear guided bearing etc.
    last year i success build 4' x 3' cnc with ballscrew 16mm diamater and linear guide bearing 20mm. but for long 9' x 5' i have difficult since its will need long ballscrew, which one better belt or ballscrew for 9' and 5' and did i need dual x gantry also?
    i have this part already :
    - gecko g202 stepper driver with 48v psu.
    - sanyo denki nema 23 170oz or 230oz. ( will i need upgrade stepper motor?)
    - mach3.
    frame probably 8020 T slot.
    Please advise.
    thank you
    Sent from my SGH-T989 using Tapatalk 2
    Nov 2011
    107
    I believe that you need to go with a rack and pinion, because of the large cnc you are planing to make, use a 3 to 1 reducction as a drive train, a ball screw is going to add a lot of inertia, and is going to be difficult to stop rotating or to start.
    Oct 2008
    Surely Rack and Pinion, as karlo pointed out. For a better choice (with a higher cost indeed), you may consider Nexen's.
    Untuk sepanjang itu, ballscrew akan melengkung. Gunakan rack-gear sebagai drivernya.
    Stepper motor sudah mencukupi (nema23 270oz), karena beban lensa laser tidak signifikan.
  1. Are you a Mechanical Engineer or know one?
    By Kosh_V in forum Employment Opportunity
    Last Post: 06-22-2011, 06:10 PM
  2. Mechanical HELP please.....
    By 1041448 in forum Open Source CNC Machine Designs
    Last Post: 02-12-2009, 06:48 AM
  3. Mechanical drawings
    By stephaan in forum Mechanical Calculations/Engineering Design
    Last Post: 10-29-2007, 06:26 PM
  4. Mechanical Stop
    By boricuajdm in forum Uncategorised MetalWorking Machines
    Last Post: 05-15-2007, 09:50 PM
