588,633 active members*
5,565 visitors online*
Results 1 to 11 of 11
    Feb 2007
    1041
    90° Beveled Gearbox ?
    I'm currently trying to locate the best price on a miniature "L shaped" 90° Beveled Gearbox. I'm working with a company that offers them, but thought I'd ask before I purchase anything.
    1. 90° 2 shaft gearbox (Price @ $50.00 each not including shipping)
    Size: 29.97mm x 29.97mm x 18.79mm
    Torque: 6 in-lbs (hardened gears)
    Ratios 1:1
    2. 90° 3 shaft gearbox (Price @ $208.00 each not including shipping)
    Size: 40mm x 40mm x 25mm
    Torque: 12.5 to 40 Inch-lbs
    Ratios: 1:1
    If you have any links to another company that can make them and offer them with a better ETA and price, please do tell.....
    Thank you
    Chris
    Jun 2008
    130
    Globalspec?
    Feb 2007
    1041
    "Globalspec"
    I've tried them in the past, really expensive. I think the Gearbox I was looking at was about $300.00 or more. Pretty much the samething, but for some reason they charge more.
    Jun 2008
    130
    Thats why I don't use it as much more than a research tool.
    Feb 2007
    1041
    How about any great places to buy smaller metric gears from ?
    I've tried SDP, Mc-masters carr for gears, to big.
    Dec 2003
    24222
    Do you need a gearbox per se?
    What degree of backlash are you looking to get?
    Have you looked at descrete Spiral Bevel and Miter & Bevel gears such as offered by Boston Gear for example?.
    If you want metric, get yourself a free Misumi catalogue for just about any piece of hardware you need.
    For miniature gears, check Winfred M Berg Inc N.Y.
    Al.
    Albert E.
    Feb 2007
    1041
    "Do you need a gearbox per se?
    For miniature gears, check Winfred M Berg Inc N.Y."
    Yes does need to be a miniature gearbox. Backlash would need to be very very low. Not sure how they really rate that, but I've seen 1 degree (not sure what that means exactly). Boston Gear is more for lager gearboxes.
    Can't find the last company Winfred M berg inc N.Y.. Have a link ?
    Jul 2005
    450
    These guys might be worth an email, they do small dc motors and gearboxes.
    http://www.mfacomodrills.com/gearbox...l_gearbox.html
    Dec 2003
    24222
    Quote Originally Posted by twocik View Post
    http://www.wmberg.com/
    1 degree would be considered high backlash.
    Low backlash would be in the order of 5 arc minutes.
    Al.
    Albert E.
    Feb 2007
    1041
    Thank you guys, I've emailed both. I'll let you guys know which works out better.
    Feb 2007
    1041
    Hi guys I've contacted
    Have you or has anyone here ever ordered from them ?
  1. Check ZX7045 GearBox
    By fcollebluegate in forum Charter Oak Automation Support Forum
    Last Post: 08-31-2007, 08:34 AM
  2. RF 45 gearbox problem need help please
    By fc911c in forum Benchtop Machines
    Last Post: 01-12-2007, 11:56 PM
  3. Beveled 1/8" endmills?
    By saturnnights in forum MetalWork Discussion
    Last Post: 03-27-2006, 01:48 PM
  4. digital lathe gearbox?
    By dberndt in forum Uncategorised MetalWorking Machines
    Last Post: 09-26-2005, 06:41 PM
  5. gearbox reduction unit
    By senor J. in forum DIY CNC Router Table Machines
    Last Post: 12-13-2004, 07:46 PM
