588,417 active members*
5,077 visitors online*
    Jun 2013
    90 VDC Power question
    Howdy... I have a 90 volt DCPM motor,1/3 hp, and rated for 1750 RPM. I realize there are these cheap SCR bridge controllers available. They can generate 90 VDC via an SCR diode bridge. Just wondering out-loud if could leverage this 90 VDC from the unit for an external h-bridge circuit? The h-bridge would merely behave as an external switch for the 90 VDC to the motor using mosfets drivers. I'd like to use the h-bridge if possible as it has more features. Anyone have any thoughts on this? Much oblige...
    Dec 2003
    24220
    You can pay a little extra and get the KB/Baldor PWM version?
    Modifying the SCR type for H-bridge would hardly be practical, IMO, there are Chinese versions out there that PWM the 120Hz ripple, but it is still relatively low frequency switching.
    Al.
    Albert E.
    Jun 2013
    Thanks for your response. BTW, Just curious... You said:
    "there are Chinese versions out there that PWM the 120Hz ripple"
    I guess I do not understand that. Can you point me to a resource that explains this a bit better? (Or a manufacturer of such a product)
  1. Power supply question
    By TarHeelTom in forum CNC Machine Related Electronics
    Last Post: 03-13-2011, 10:22 AM
  2. Power supply question
    By gavztheouch in forum CNC Machine Related Electronics
    Last Post: 06-03-2009, 08:21 PM
  3. Power supply question
    By jhowelb in forum CNC Machine Related Electronics
    Last Post: 02-01-2008, 07:53 PM
  4. Power supply question, AC or DC?
    By Corruptor in forum CNC Machine Related Electronics
    Last Post: 02-26-2007, 08:54 PM
  5. Power Supply Question
    By jjwl89 in forum CNC Machine Related Electronics
    Last Post: 07-21-2004, 03:51 PM
