588,385 active members*
5,453 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > 907 Alarm-C lube tank flow 1/LB15
    Jan 2006
    121
    Our LB15/OSP5020L is giving a "907 ALARM-C lube tank flow 1" alarm. I've taken the lube line loose at the pump and cycled it and it's delivering oil from the pump.
    Any ideas?
    Thanks,
    Jon
    Jan 2009
    74
    there is a flow switch either in or out of the tank that monitors oil moving. the outer unit is usually a brass unit that has 2 wires going to it and if you take it apart it will have a ball in it checking the flow by raising the ball. the inner style i am not sure about.
    Jan 2006
    121
    Smile Problem resolved
    Well after fighting with getting the lid off the pump (somebody siliconed it good), and cleaning the pickup screen, it now seems to have fixed the problem.
    By the way this had the internal pressure switch, which was like a mini hydraulic cylinder that actuated a micro switch.
    Jon
  1. Alarm (low lube,pressure) question
    By BMackinnon in forum Haas Mills
    Last Post: 05-31-2020, 12:53 PM
  2. Fanuc O-md Lube Time Alarm!!!!
    By sco999 in forum Fanuc
    Last Post: 09-16-2018, 05:59 PM
  3. re Spindle Lube and Lube Pump
    By robkuhi in forum Tree
    Last Post: 10-24-2011, 06:49 PM
  4. Video on LB15
    By beartrax in forum Okuma
    Last Post: 08-27-2008, 04:04 AM
  5. OKUMA LB15 "ALARM 206 A Shear Pin 4"
    By RISNA in forum Okuma
    Last Post: 06-16-2008, 04:35 AM
