587,243 active members*
3,229 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > 95 hawk ssm mirror function
    Sep 2007
    Question 95 hawk ssm mirror function
    I have a 95 hurco hawk with a single screen ssm control I bought used a few months ago. I tried using the mirror routine today but could not get it to work. I followed the example in the manual but no luck . Is there something I need to know that isn't in the manual?
    Thanks for any help
    Dan
    Jan 2005
    49
    Probably a Hawk 5? Yes the mirror function works very well. A real plus is if your climb cutting, your mirrored cut will also climb cut. The manual should be good on mirror patterns. Do Original- selects whether to do both the original and the mirror image or just the mirror image. Mirror about- determines whether to mirror left/right (90) or up/down (180). The X and Y demension determines the point about which to mirror the part. This point is reference part zero. If you use a pattern/mirror image block, be sure to use a pattern end block. Pattern/mirror image---mill block---pattern end. Pattern/mirror image---holes block---pattern end. Any pattern block must have a pattern end block to close it out. You can nest patterns within patterns. But, each pattern block must have a pattern end block to close the pattern. Ron
  1. Cincinnati Hawk 150
    By madmike46 in forum Cincinnati CNC
    Last Post: 05-22-2018, 10:25 AM
  2. Hurco Hawk 30
    By jack_1960 in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2007, 01:27 PM
  3. Mirror function
    By SWPM in forum Surfcam
    Last Post: 08-17-2007, 10:04 PM
  4. Cincinnati Hawk 150
    By madmike46 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-10-2007, 04:32 AM
  5. cincinnati hawk 150
    By madmike46 in forum Uncategorised MetalWorking Machines
    Last Post: 07-01-2007, 03:16 PM
