![Quote](images/misc/quote_icon.png)
Originally Posted by
GITRDUN
We have a '97 (maybe 98 i dont recall) VF-3 with the Mitsubishi spindle drive. The drive burned some traces on one of its boards so we purchased a new drive. Got the parameter list from HAAS service and installed the drive then changed its parameters accordingly.
Now when trying to start the spindle it will stutter back and forth, sometimes after a few seconds will then take off and run at correct RPM, most times will simply stutter until you hit RESET. It will run well enough below 100RPM so that the orientation for tool change works fine. But trying to start the spindle manually or by program just doesnt happen.
I talked to HAAS tech and they said to call Mitsubishi tech since it is a Mitsubishi drive. Mitsubishi tech turned out to be the worst phone tech experience i have ever encountered by far. Maybe ive just gotten spoiled from the many calls to NYMAT. So anyways, im almost certain we have a spindle drive parameter that just needs tweaked but im hesitant to just start playing around with them. Does anyone here happen to have a parameter list for this drive? Or have some advice on what parameters to tweak? The machine has the 7,500RPM 15HP motor.
