I have been searching and I have not found a mod or a replacement for the stock graduated dials on the cross slide hand wheel or the compound hand wheel...
my issue is the dial spinning around from vibration or by using the handwheel.
i drilled and tapped a set screw to try and fix this but on the cross slide it seems to bind the motion if it is tight enough to lock the dial in place....
I have seen the bearing mods which I would like to do but the dials are baffling me. this mabye just my inexperience on how to use them but i just feel that there should be a better system for these..... has any one fixed this problem and or know where I can find a modification for them???
thank you in advance......
Sebashtion H.
