587,997 active members*
1,791 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > A/C Motor Turning Wrong Direction
    Mar 2013
    I am currently in the process of retrofitting a CNC bench top lathe. When I received it the motor spun the correct direction. I stripped all of the old electronics out a few weeks ago. Today I hooked the motor up to test it and it turns the wrong way. I am certain I am just hooking it up wrong. I was wondering if anyone could help me with the correct way to hook it up. It has 4 wires ground (green), neutral (white), run coil? (black, 6 ohms), and the start coil? (red, 3 ohms). I think I may have the run and start coils mixed up and I am not entirely sure I hooked the start capacitor up correctly.
    My current set-up:
    Ground-->Ground
    Neutral-->Neutral
    Live-->Run Coil
    Live-->Capacitor-->Start Coil
    Any help would be appreciated.
    Dec 2003
    24220
    If you have both ends of the start winding, just reverse them.
    You have to swap the start winding with respect to the run winding.
    with only three supply conductors, you must have swapped a connection in the motor terminal block?
    Al.
    Albert E.
  1. Z-axis only turns in ONE direction, anyone know what might be wrong?
    By effimos in forum DIY CNC Router Table Machines
    Last Post: 03-15-2012, 01:20 PM
  2. lathe, cutting in wrong direction.
    By bert7 in forum BobCad-Cam
    Last Post: 11-03-2011, 10:54 PM
  3. Z axis going in wrong direction
    By erkiwi in forum CNC Machine Related Electronics
    Last Post: 01-20-2010, 11:43 AM
  4. Slow Homing/Wrong direction
    By SeanO in forum Stepper Motors / Drives
    Last Post: 01-22-2009, 10:25 PM
  5. integrex 200 II SY b axis wrong direction
    By smile in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-07-2006, 05:09 AM
