Well,
The MDF "pawl" which is the ratchet mechanism that allows the clock to be wound up lost it's spring tension and was allowing the weight to suddenly drop to the floor. In the interest of safety I took it down untill I could cut a new pawl from a more suitable material (maybe quality plywood). I havent cut one yet, so it was only in operation for a couple months.
I had plans to cut another complete clock from hardwood or plywood but that hasn't happened either....maybe I should spend less time posting and more time "doing".
Sorry I can't give you a better answer.
E
I wish it wouldn't crash.
