587,999 active members*
2,337 visitors online*
Thread: A cnc clock
Page 4 of 4 234
Results 61 to 70 of 70
  1. #61
    Mar 2005
    65
    Cutting
    I am trying to make the conversion into CNC I have some basic drawings that I am starting with. How do you go from .DXF to gcode? Did each part have its own file? I was looking at some of the cam software and its up in the price range. For a hobby that is far much to pay. I do have a student version of solidworks 06 that is fully functional but there is no option to output a DXF unless the part is in a drawing and when you create a drawing the dimensions change.
  2. #62
    Mar 2003
    294
    Hey ClockMaster,
    Ahhh, just starting out...how fun!
    I have a lot of info for the beginner and my trials and errors at my site.
    www.cuttingedgecnc.com
    I have CAM programs I have played with here http://www.cuttingedgecnc.com/programs.htm
    You don't have to only be able to save in dxf. It depends on what your CAM program likes (but dxf is probably the most common.)
    hope that helps
    Thanks,
    tauseef
  3. #63
    Mar 2005
    65
    Thank you for the fast reply. I have been reading and reading and there is still way too much more I need to learn. I will check out that link.
  4. #64
    Mar 2003
    35538
    Quote Originally Posted by ClockMaster View Post
    Set up the drawing at 1:1 scale, then save as .dxf
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  5. #65
    Mar 2005
    65
    Still no luck with converting the dxf to NC
  6. #66
    Apr 2006
    3498
    great Job please continue posting plans for the clocks
  7. #67
    Apr 2004
    30
    Clock 1
    Hi all...
    Just ran across this thread so I thought I had better post a couple of pics of my project done three or so years back.
    Larry
  8. #68
    Apr 2006
    3498
    gr8 clock
  9. #69
    Dec 2007
    12
    Did you have to offset the DXF drawings before you generated the G-Code. I'm having problems getting the cogs to look like cogs when I cut.
    Thanks,
    Oldbill
  10. #70
    Mar 2003
    2139
    Depends. If using ace converted, then yes, you need to offset. I did this on a new layer.
    I wish it wouldn't crash.
Page 4 of 4 234
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Making money with CNC
    By Johnuk in forum Community Club House
    Last Post: 12-13-2009, 05:46 PM
  3. Beginners CNC Advice
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 10-08-2009, 05:10 PM
  4. Newbie to CNC world
    By HighOctane in forum DIY CNC Router Table Machines
    Last Post: 01-25-2005, 08:58 PM
  5. The start of a big CNC project...
    Last Post: 09-30-2004, 11:34 PM
