588,219 active members*
4,226 visitors online*
Page 27 of 29 172526272829
Results 521 to 540 of 569
  1. #521
    Nov 2005
    655
    I don't know if this would be a good idea or not, but here it goes......
    Instead of mounting the motor hanging down (like the stock motor mounts), mount the motor standing up. Build a stand-off on top of the stock motor mount plate to space the motor above the machine.
    Hope that makes sense.........
    Cheers,
    Jack
    P.S. That's a BIG motor
    Walking is highly over-rated
  2. #522
    Nov 2005
    655
    Oops...........
    Looks like you had the same idea already
    I type really slow.......................
  3. #523
    Jul 2008
    922
    no worries mate! i like the riser idea as that would give me more clearance at the bottum of the left over the stock motor. but i skipped my last period today to come home and draw up what i had been mulling over all day... i think im done designing the bracket
    its hard to see how it goes together in the drawings.. man i need to learn how to do 3d in autocad... but there will be ~ 2.5" tall .75" diameter aluminum that i will turn on my mill (.75" is my biggest collet) which will rise the top plate from the bottum plate.
    Right now im off to go pick up an order in pasadena from littlemachineshop... chris wood is a great guy its nice to be able to drive 30 min and avoid a $30 shipping charge on a surface plate...
    Cheers!
    edit: had to make some changes on the motor plate as duh, forgot my y axis travel
    Attached Files Attached Files
  4. #524
    Jul 2008
    922
    quick question.
    is it necessary to fuse the AC line right before the vdf? or is it internally fused... i thought i had some fuse holders but looks like i don't...
    cheers
  5. #525
    Jul 2008
    922
    [ame="http://www.youtube.com/watch?v=U4R-p4DWInU"]YouTube- cutting new motor mount on cnc x3[/ame]
    heres a link to a boring video... only watch it if you are really bored lol. i finished up wiring and programming the vfd today (man i love it) and am going on the new motor mount now.
    cheers
  6. #526
    Dec 2005
    11
    I have alwys preferred using circuit breaker in my electrical installations as you get a visual indication of the trip. That said, I understand that automationdirect offer fuse blocks as an option, i.e they are not internally fused.
    Cheers,
    Mike
  7. #527
    Mar 2006
    474
    Quote Originally Posted by Teyber12 View Post
    That's not boring, all of us find metal cutting interesting, or we wouldn't be here.
    Quit using your fingers to clear swarf.
    http://www.youtube.com/user/vlmarshall
  8. #528
    Dec 2005
    430
    OMG, use a paint brush to clear the chips!! you crazy machinist :P
    aaaaaaannnd i wonder how something like that motor and vfd would work on an x2....
    Shaun
    my x2 conversion ------> http://www.cnczone.com/forums/showthread.php?t=36403
  9. #529
    Jul 2008
    922
    mjrandal, thanks! i decided to stop being lazy and picked up a inline fuse holder at radioshack.
    vlmarshall: I need a enclosure and flood coolant to clear the chips instead of me ha. i will look for a brush i don't know why i didn't think of that... and thanks
    skmetal: scope something like this...
    http://www.automationdirect.com/adc/.../MTR-P75-3BD36
    theres also a .5hp one. Make sure you check the dimensions (like i didn't) lol to make sure it would work. im not sure if that would fit on a x2 after further thought... 6.9 inches in diameter. you think it would work?
  10. #530
    Dec 2005
    430
    yeah im not sure it would work. the motor would probably be bigger than the entire head assembly! but this dc motor has almost no torque, especially at low rpm. i was also thinking ac servo, but trying to find a motor and compatible drive is not fun, or cheap.
    Shaun
  11. #531
    Jul 2008
    922
    heres the finished top plate
  12. #532
    Dec 2005
    430
    ooooooo spiffy!
    what cad/cam prog do u use?
    Shaun
  13. #533
    Jul 2008
    922
    [ame="http://www.youtube.com/watch?v=vS6qnSHpVDY"]YouTube- 802 0192[/ame]
    finished up the wiring... i mounted the vfd in that plastic case haha and i will tilt it upright and put it behind the computers. It gets hot and needs airflow but gotta watch out for the chips. cheap and functional ha
    and im using autocad/dolphin cad for cad and dolphin for cam.. can't speak highly enough of dolphin cam..
  14. #534
    Nov 2005
    264
    that is one honkin motor. can't wait to see it mounted running the mill
    FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
  15. #535
    Dec 2007
    496
    pretty nifty my friend
  16. #536
    Mar 2008
    3655
    wow! Looking good!
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
  17. #537
    Dec 2005
    11
    Hi Teyber,
    I can't quite tell from the movie what type of cable you are using between the VFD and motor, but I suggest you Google "VFD cable" and source some shielded cable.
    Cheers,
    Mike
  18. #538
    Jul 2008
    922
    thanks gang!
    mjrandle: no i am not! i am using 12gauge stranded wire with plastic wire loom... it was not the cheapest and i cannot imagine vfd cable is cheap. Is it just shielded wire? i have 22 guage(or is it 18 guage) shielded stepper motor wire, i wonder if using that and double wiring the motor would work? (as in 2 cables carrying the current for 1 wire)
    Is the problem electrical interference?
    And i finally got around to re-ordering the new gears. 10 emails no response from sd-spi or w/e their name is. can't recommend them. but they were the only place that had what i needed hurts to throw $100 down the toilet, especially when there is so much else id like to buy. I got a lot of little projects slowly working and i will be keeping you all updated.
    1) vfd motor with belt drive mach3 controlled
    2) sealed home switches on x,y,z
    3) install x/y motor covers(done)
    4) power drawbar
    5) enclosure
    im in a "get it done" mood. look out!
    Cheers!
    edit:
    before i order...
    http://www.alliedelec.com/search/pro...px?SKU=6422297
    will these work as home switches for x/y/z? i know they are limit switches but i think they will work as home switches. Just don't want to waste anymore money so double checking here
    thanks!
  19. #539
    Jul 2008
    922
    hey guys
    getting real annoyed here... My e-stop switch keeps activating mid-part... for about a week now. its ruined a lot of parts. I have visually checked the connections and it doesn't appear to be the e-stop wiring. What usually causes this? the computer im using is pretty darn old and im hoping its not biting the dust.
    When i restart the computer the problem temporarily goes away so i think im slowly going to start building up a new computer. bad timing, i was wanting to build a enclosure before i did this.
    Thanks in advance
  20. #540
    Dec 2005
    430
    do you have your e-stop wires running close to any motor/ high current wires? i had mach saying "external e-stop requested" at random times, and i had my e-stop wires running next to my spindle motor wires (DUMB!), must have been coupling a current into the e-stop signal wiring. disabled the e-stop temporarily, so far i haven't had it trip.
    my comp. is an old 900mhz, 512MB, 32MB graphics card. every once in a while i'll get a "driver watchdog triggered" from mach, but never when a program is running.
    Shaun
  1. New guy with a couple of questions
    By blackhollowmfg in forum Waterjet General Topics
    Last Post: 01-31-2007, 07:58 PM
  2. Couple Questions
    By CNCoperator123 in forum DIY CNC Router Table Machines
    Last Post: 09-21-2006, 07:21 PM
  3. saying hello with a couple of questions
    By JonC in forum DIY CNC Router Table Machines
    Last Post: 06-27-2006, 05:57 PM
  4. Couple New Guy questions
    By Black Mesa in forum Open Source CNC Machine Designs
    Last Post: 06-13-2006, 10:40 AM
  5. A couple of questions about MC
    By Tarkus in forum Mastercam
    Last Post: 12-28-2005, 04:59 PM
