I need some parts machined from 3/8" & 1/2" Aluminum.
1x_DrivePlate.SLDPRT 3/8" Alu 1 Piece
2x_DrivePlate.SLDPRT 3/8" Alu 2 Piece
3x_DrivePlate.SLDPRT 3/8" Alu 3 Piece
2x_Bracket.SLDPRT 1/2" Alu 2 Piece
Have you tried Big Blue Saw ?
elogica. I cant read your files in this format. Can you post some cad files? If its 2D then dxf, if 3D how about STEP. I do a lot of aluminum work. Mike.
Web site is conmach.com
quote sent by private message.
mike
[email protected]
www.hessemachine.com
You have a P.M.
Thanks,
Steve
Here are .step files of the parts +/- 0.1mm would be nice shipping max 7 days from po, need prices in by mid week
A couple of questions. Are the .201 and .125 diameter holes on the drive plates cearance holes? And are the 3 .201 holes that are .8 deep clearence holes or threaded. I got no call outs or dimensions with the step files and I know it should be obvious but I just want to make sure. Mike. conmach.com
Deadline is currently floating will draw up a set of dxf's this weekend.
Chris
Sent you a PM.
Trevor
can you also send me dxfs and any other info. you may have i will quote asap.
thank you
i would also like some dxfs as i can't read solidworks parts.
