603,800 active members*
3,113 visitors online*
Results 1 to 5 of 5
    Jun 2004
    5
    a little conversion
    I cannot seem to find the conversion for kg-cm into oz-in can some please help. I have a motor that reads 4.1 kg-cm and I need to know the oz-in of the motor. Thanks for your help
    Aaron
    Oct 2003
    927
    This may help..
    there is a small program called "convert" that maybe can be found doing a search.
    ..also this
    www.onlineconversion.com
    Jan 2005
    746
    Well I hope I did the math right. It' been a while.
    1 kg=2.2 lbs
    1 lb= 16 oz
    1 in=2.54cm
    4.1(2.2)(16)=144.32 oz
    144.32/2.54=56.81 oz. in.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Jun 2004
    5
    Cannot think you guys enuff. And that my friends is why I think this is such a good place with good people. Post a question go make a pot of coffee and by the time your back problem solved. I have the convert program but it is very old and did not have every thing I needed to convert. Looks like its time to update.
    I thank you all
    Aaron
    Mar 2003
    35494
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Need Advice for Clone Conversion
    By lerman in forum Bridgeport / Hardinge Mills
    Last Post: 04-17-2006, 07:48 PM
  2. First Impressions for CNC mini mill conversion
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2004, 03:37 AM
  3. Newbie Looking for Advice (Sherline or HF Conversion)
    By Deviant in forum Benchtop Machines
    Last Post: 09-27-2004, 02:10 AM
  4. Mini lathe conversion
    By kdoney in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2004, 04:21 AM
  5. possible cnc conversion on homier mini mill
    By WsW-WYATT in forum Benchtop Machines
    Last Post: 03-27-2004, 02:24 PM
