603,799 active members*
2,834 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > A little help hooking up Geckos please
    Jun 2003
    167
    I have Gecko 320's and am using them with Mach2 on servos. I am confused, the information with the Geckos says you don't need a seperate 5vdc power supply for the encoders on the servos hooked to the Geckos, then later it tells you to hook up a 5vdc supply to the last pin. My encoders should fall under the 50mA encoder limit. What am I missing? Which is it, do I need to hook up a seperate 5vdc to the last pin or ignore it? I really don't want to let the magic smoke out of them. Thanks for the help. Ron
    Jun 2003
    167
    Never Mind, I figured it out. Thanks
    Aug 2005
    31
    coudl you please let me know what did you do? im trying to use the same driver and mach3...regards
    MARCOS
  1. Hooking up HobbyCNC board and motors to PC...
    By jdbaker in forum Hobbycnc (Products)
    Last Post: 06-06-2005, 07:10 PM
  2. Hooking it all up
    By Dylwad in forum DeskCNC Controller Board
    Last Post: 05-02-2005, 06:38 AM
  3. My geckos have a mind of their own
    By bgolash in forum CNC Machine Related Electronics
    Last Post: 04-30-2005, 06:08 PM
  4. Gecko's faulting
    By dowling177 in forum Gecko Drives
    Last Post: 04-08-2005, 08:02 PM
  5. Turbo CNC and geckos
    By snoman70 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-30-2005, 01:47 PM
