587,786 active members*
2,265 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > A Little Help Please
Page 1 of 2 12
Results 1 to 20 of 21
    Nov 2012
    16
    So i have finally built my machine. now having a little trouble when getting a new arm made up i will explain so i have drawn up my design in solid works and saved it as a .igs file opened the file in bobcad sorted all the machining out in bobcad but when profiling the arm every pass it moves away by a few mill have attached a photo it is quite hard to explain at first i thought it might be the drawing so redrawn the whole thing but same thing happened don't have a clue been scratching my head past few days trying to figure it out will appreciate any help thanks
    Attachment 180931
    Attachment 180932
    Attachment 180933
    Dec 2005
    121
    A Couple of questions first . Which toolpath in Bobcad did you use ? Profile ect. Does this occur in the Gcode or just at the machine . It this is not occurring in the Gcode program than it would be a machine issue. Movement in guides or part it self... Please posts bobcad file with toolpath and seperate posted Gcode file for us to look at.
    MikeG
    Nov 2012
    16
    code
    Nov 2012
    16
    there's the code problem is on job 4 still doing the same thing
    Apr 2009
    3376
    WOW,you got some serious tool deflection issues.To better help you a few questions.What kind of endmill you using,and is it High Speed Steel or Carbide.Give us an idea of what kind of machine is being used here.Name,model,Horse Power.Also tell us your max. RPM
    Aug 2012
    621
    I'm tempted to look at hardware on this one, as well. You say it's a new home-built machine? It frequently happens with new machines that things like shaft couplings aren't as tight as they should be, and slippage occurs. It's hard to tell from the picture, but it looks as though the actual toolpath is offset mostly in one direction. That's just what you'd see with a slipping coupling.
    Not saying that's definitely the problem, but I'd sure check to see.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Nov 2012
    16
    hey made the machine myself the endmill was a 6mm carbide and the spindle is a 2.2kw huanyang water cooled 220v Chinese spindles that are all over ebay have ball screws an all three of the axis was running the spindle at 12000 rpm
    Attachment 181123
    Attachment 181124
    Attachment 181125
    Nov 2012
    16
    hey Luke
    checked to make sure seems everything is tight thing is it leaves the same amount of material on every pass so every layer is exactly the same size surely with slipping it will be all over the place? not sure
    thanks
    Apr 2009
    3376
    If you got ball screws,you should be climb cutting.The .bbcd file you zipped,it had it set for conventional.But that ain't your problem.
    One thing that for sure will do this is if your spindle is not Trammed in.It kinda of looks off,but it is a picture I am looking at.Do you know how to do this?
    I do not believe BoB is behind this.It is a Machine thing.Tram the spindle,and let us know.
    I think you should also try posting your question here http://www.cnczone.com/forums/diy_cn...able_machines/
    Nov 2012
    16
    not even heard of tramming just googled it would i need a tram tool or is there any other way of doing it?
    Aug 2012
    621
    You'll need a way to clamp the arm for a dial indicator to the shaft of, say, an endmill. Basically, the dial indicator needs to be able to sweep in a plane that's perpendicular to the spindle's axis of rotation. The rig I've used consisted of a block of wood that was drilled for 1/4" in the top and 7/16, I think, perpendicularly through the side. I then sliced it through the axes of the two holes, allowing me to clamp it down over an endmill and the arm that held the indicator. Kinda ghetto, but it worked.
    There are store-bought solutions, of course. You see ads for them on this site all the time. Looks like 2 dial indicators with a bridge between them, and a shaft going up. You can do it with just one indicator, though.
    Once you have a way to hold the indicator out to the side of the rotation axis, then you can read the depths all around the spindle, to the work surface, and adjust the spindle until it's the same in every direction. Then, your endmill will be as vertical as you can make it.
    I agree with Jrmach, you should post your situation over in the DIY CNC Router Table forum. It's not that we don't like you, but you'll have more people over there with similar machines and likely get more and better response from them.
    Luke
    Sep 2012
    1195
    It looks like mechanical slippage on one axis. The steps don't look perfectly uniform, so I doubt it's an issue with the controller or other electronic hardware. Measure the steps with some digital calipers. If they are all identical, then I'd suspect the electronics are not set up quite right. If they vary, then I would suspect the mechanical components of the axis are either slipping or binding.
    Sep 2012
    1195
    If the angle of the spindle is off, the result will be a sawtooth on one part edge (which is still square overall, but with teeth). The opposite side of the part will have no sawtooth, but an angled edge. The photos do not appear to indicate the spindle is out of square, IMHO.
    Jul 2009
    82
    Post edited,
    V25, Dell T3700 Xeon, 16GB, Nvidia 4000, Win 7 64bit 2 x 22" Dell Monitors.
    Moulds completed: 130
    Nov 2012
    16
    hey thanks that sorted the problem
    Nov 2012
    16
    you where right spindle needed tramming thanks
  17. #17
    Feb 2006
    22
    shiv15uk63
    i ran each pass thru tape to shape and they were all the same so it defenately is not the code maybe you could answer something for me how do you like spindle does it have good power at all speeds
  18. #18
    Feb 2006
    22
    removed
  19. #19
    Feb 2006
    22
    removed
  20. #20
    Feb 2006
    22
    removed
Page 1 of 2 12
