587,792 active members*
3,396 visitors online*
Results 1 to 5 of 5
    Jan 2007
    117
    A Small Lathe Router
    Just finished construction of a small lathe router. It accomodates a workpiece up to 9 inches long and 7 inches in diameter.
    The rotary axis is a used Taig lathe (no lathe motor). The lathe spindle is driven by a belt connected to a stepper motor working into a 50:1 reducer.
    A Picture is here:
    http://www.flickr.com/photos/11132086@N02/2111286068/
    Several other pictures are there and can be accessed by clicking on the photostream.
    Aug 2004
    3215
    Thats a nice looking little machine.
    Mar 2006
    427
    Looks nice but I have to ask what are you making on it can we see some photos. I ask because all your machines look great I just wonder what you make with them.
    Jan 2007
    117
    What I Do With My Machines
    Quote Originally Posted by Regnar View Post
    I most likely won't use this machine for a month or so. Plan to use it
    to create spiral patterns and engrave/carve the outside of cylinders.
    My strategy for this machine is to define the rotary axis workpiece as a linear plane. I did a spreadsheet that shows the diameter needed to create a specific circumference. Blanks are first turned on a engine lathe to the needed diameter. The spreadsheet also shows the steps/unit to be entered into the Mach 3 configuration since it will be different for various diameters.
    Hope that made sense.
    What do I do with my machines?
    My website is under construction waiting for photography. There is a picture there now. The URL is http://www.joekuter.com
    Really nice machine.
    Please check out my CNC blog
    http://cncinside.com
  1. Replies: 15
    Last Post: 05-05-2011, 11:59 PM
  2. Which small lathe in UK?
    By martinw in forum Mini Lathe
    Last Post: 02-27-2008, 08:31 AM
  3. RFQ - Small lathe job 100 qty.
    By warpedmephisto in forum Employment Opportunity
    Last Post: 08-02-2006, 09:51 PM
  4. Lathe Comparison - Best small lathe for CNC
    By acondit in forum Mini Lathe
    Last Post: 03-24-2006, 02:10 AM
  5. RFQ: Small mill/lathe job
    By vadimvc in forum Employment Opportunity
    Last Post: 03-14-2006, 05:10 AM
