603,996 active members*
3,771 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > A way around the 9999 program line limitation?
Results 1 to 4 of 4
    Aug 2009
    23
    I have an older Fanuc 6m Controller. The Memory has been upgraded so I can fill it with data. However the programs are limited to 9999. I've thought about doing the subprogram thing, but then would this be done by a post processor that will do it automatically? Or another way around this issue?
    Thanks for any info!
    Mar 2003
    2932
    You aren't limited to 9999 blocks. You're limited to 9999 block numbers.
    See if you can turn off block numbering in your post-processor.
    Feb 2007
    592
    Quote Originally Posted by dcoupar View Post
    Exactly - Only use Nxxxx on safe start lines for each tool.
    Feb 2006
    1792
    I use N-numbers only if these are absolutely necessary.
    I believe, duplication of block numbers is permitted, if the such numbers are not being referenced in the program. So, after 9999, you can again start with 0001.
  1. Fadal 4020 stops at line 13 or 16 in program
    By ThatguyDave in forum Fadal
    Last Post: 09-09-2009, 08:57 PM
  2. fadal cnc 88 program limitation at line 734?
    By Runner4404spd in forum Fadal
    Last Post: 03-04-2009, 03:21 PM
  3. Today's favorite line drawing to g-code program
    By IQChallenged in forum G-Code Programing
    Last Post: 12-27-2007, 07:57 PM
  4. On Line sizer program, Steppers or Servo
    By Al_The_Man in forum Stepper Motors / Drives
    Last Post: 07-12-2005, 06:47 PM
  5. total line length program?
    By ljoe1969 in forum Uncategorised CAM Discussion
    Last Post: 01-09-2004, 05:27 PM
