587,374 active members*
3,308 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > about centro/coaxial watches
Results 1 to 5 of 5
    Jun 2015
    4156
    Hello, i use a Haimer ( pls see attached photo ), that has 3mm range
    This watch arms at the middle of the range, 1.5 mm, and i was wondering if you know watches that arm just a bit, ~0.2 for example ?
    Asimeto version ( pls see attached photo ) seems to have a fine adjustment ... does anybody know if this one arms just a bit, and not at middle-range ?
    [ Middle-range arming ] + [ watch retreat and reenter ] = [ palpator broken ]
    Of course, you can arm just a bit using a pupitast ( pls see attached photo ), but their range is short ( ~0.8 ), and if missalignment is >0.8, than you put extra-force on internal mechanism.
    Centro Watches have greater range, while pupitast allow soft-spring-arming. I need a combined version please
    Apr 2009
    1262
    Re: about centro/coaxial watches
    Blake, fowler, and SPI all make coaxial indicators as well as others. I would think that one of the makes what you are after . We use a Blake and it works well until it gets "abused " by a careless user. Several are on eBay.
    Best regards
    Jun 2015
    4156
    hello, is allways nice to hear from you
    Jun 2015
    4156
    please, about your Blake, does it arms always at middle-range, or is it possible to arm only 0.1-0.2 mm ?
    i would really apreciate a coaxial, with 0.1 arm and 3..4 mm range , but i don't think it exists
    Apr 2009
    1262
    I'm not 100% sure what you are trying to accomplish, but the Blake we use is very similar to the Asimeto unit you show. I believe that the rage may be larger, but if you visit their website they can give you the specs of what they offer. They have several different diameter Styli for the end and different resolutions and spring options available.
    Blake Manufacturing Co.
    SPECIFICATIONS
    Length: 6 7/8 in.
    Shank 3/8 dia. x 7/8 in. long
    Weight 9 1/2 oz. net
    1 LB. 14 oz. shipping weight
    Feeler ball 1/8 in. dia.
    Measuring Range .250 axis offset
    *Capacity Internal, 5/32 to 4 1/4 dia.- External, zero to 4 1/4 dia.
    Speed It is recommended that operating speed not exceed 800 RPm approx.
    Locating accuracy: To within .0002 in. of true center.
    Inital positioning: Within 7/16 dia. circle of true location.
    *Capacity can be increased to 12" diameter by use of accessory feelers
    Click here to view the Dial Graduation Values for the CO-AX INDICATOR
    (Above from their website)
    Best regards,
  1. COAXIAL INDICATOR
    By tjd10684 in forum MetalWork Discussion
    Last Post: 01-18-2019, 12:51 PM
  2. CNC Making a Wrist Watches Housing..
    By Harpye in forum Wooden Clocks
    Last Post: 06-23-2016, 03:04 PM
  3. Coaxial indicator
    By scrambled in forum HURCO
    Last Post: 12-15-2013, 09:01 AM
  4. risk of producing tubes for watches
    By mkhairi in forum CNC Swiss Screw Machines
    Last Post: 08-20-2011, 07:07 AM
  5. Best Coaxial indicator to buy?
    By aaron p in forum Community Club House
    Last Post: 03-05-2009, 08:30 AM
