Hi Guys !
Don't laugh, but I'm having problems routing simple ABS. The cutter clogs up (melts) the ABS and breaks the cutter. I've varied spindle speeds, feedrates, cutting depths without any luck. I used a 2 flute endmill and got it buggered up in no time. Best result so far was with a 3mm single flute cutter, but I need to cut some profiles with a 2mm tool.
Haven't had any problems cutting any other plastics or allu.
Any (working) advice will be appreciated
Fanie
