587,754 active members*
2,964 visitors online*
    Jul 2010
    Absolute position data lost ATC Matrix VCN 510C
    hi
    The problem is that the battery of the MR-J2-60ct ATC was consumed and lost the absolute system. errors 302
    I did the procedure and recovery of absolute system, of the ATC
    In the unit MR-J2-60ct ATC: errors are Z0 02 and M1 01
    apparently there is a communication error between the PC and the drive amplifier MR-J2-60ct, I think that's the problem.
    I hope you can help me, thanks
    Mar 2009
    109
    When exactly do you get the write error...when you're trying to restore the position or at start-up??
    If it's when you're trying to write, perhaps you have the write protect signals on.
    Put the drive in Test Operation and then minimize the window. This should release the write protect signal.
    Power off/on the main breaker TWICE.
    Sep 2008
    93
    alarm M0 01
    when executing dog-type reference point, the zero point return speed is too fast or the dog length is too short.
    lower the zero point speed.
  1. rover 336 data lost
    By freezengate in forum CNC Machining Centers
    Last Post: 11-17-2010, 10:07 PM
  2. LOST B POSITION
    By dowen in forum News Announcements
    Last Post: 09-15-2010, 03:31 PM
  3. Replies: 4
    Last Post: 03-03-2010, 12:56 AM
  4. Fanuc 11M Absolute position probs
    By trotsky in forum Fanuc
    Last Post: 11-05-2007, 08:29 PM
  5. Absolute position PROBLEM
    By Darkos in forum Fanuc
    Last Post: 10-18-2006, 09:26 PM
