586,069 active members*
3,275 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > AC induction motor and a vfd
    Jun 2020
    9
    I have a 2HP 2 pole inverter duty induction motor. Its I rated for 440V at 50hz and 3000 rpm.
    Now the rated torque is not mentioned, but it would be around 4.78N, gathered from some equations.
    What would be the available torque at 25Hz?. Does reducing frequency and speed give more torque?
    T= (60000*power)/(2?*RPM)
    Does power change with frequency? The RPM reduces, the torque should increase right?
    Inverter duty motor, so heat not a problem.it has seperate cooling from factory.
    Jan 2005
    15362
    Re: AC induction motor and a vfd
    Quote Originally Posted by Akhil View Post
    Using a normal V/F mode VFD the torque would be half at 25Hz
    With a VFD Drive that has Vector Torque control you can achieve a constant torque with more efficiency
    Mactec54
  1. Replies: 19
    Last Post: 12-19-2017, 01:43 AM
  2. Induction motor
    By HorridHenry in forum CNC Machine Related Electronics
    Last Post: 02-22-2012, 03:26 AM
  3. AC induction motor
    By Joe Weldor in forum CNC Machine Related Electronics
    Last Post: 02-19-2011, 07:26 PM
  4. Regeneration from induction motor with DC?
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 06-22-2008, 02:54 PM
  5. Induction motor + VFD ?
    By greybeard in forum Phase Converters
    Last Post: 10-29-2006, 12:24 AM
