603,369 active members*
3,216 visitors online*
IndustryArena Forum > CAD Software > Autodesk > ACAD formula help please
    Nov 2005
    1468
    Is there any way to put a formula into AutoCAD? What I want to do is tell ACAD that the Z value on a 2D surface is a function of X so that if I then say, ok X=0.01 it will calculate the Z value for me and stick a point on my drawing (I want to link all these X,Y points obviously).
    There will be many points... like the total X travel will be around 20mm and the X increment about 0.01mm (giving 2000 X,Y points).
    I have looked through the ACAD help files to no avail and searched CNC zone here too..I'm at a loss.
    I'm only asking cos I was going to write my own programe to do it, but if ACAD can do it this will save time (of which I do NOT have a lot at the moment hehe).
    Any ideas, as always, greatly appreciated- many thanks in advance.
    Iain.
    I love deadlines- I like the whooshing sound they make as they fly by.
    Aug 2010
    90
    hy'ya Imancarrot, think I got your gist, 3 dim.(axiis) variable input, should be pos. with AutoLISP, what version AutoCad will you be using-kelef - darn it, done it again - forgot to check the thread date :cheers: :rainfro::rainfro::rainfro:
  1. how do i get my cnc to cut my acad dwg?
    By ljoe1969 in forum Autodesk
    Last Post: 09-17-2016, 04:13 AM
  2. Acad 2000 Solids Manipulation Question
    By mcyr in forum Autodesk
    Last Post: 05-13-2007, 09:01 PM
  3. Acad 07 to mastercamX
    By Demon440 in forum Mastercam
    Last Post: 01-04-2007, 04:04 PM
  4. Is it possible to take parts of an Acad drawing
    By Spitfire in forum Autodesk
    Last Post: 04-13-2006, 09:53 PM
  5. ACAD 2002 issues????
    By DanFri in forum Autodesk
    Last Post: 07-02-2003, 07:16 PM
