Here are some numbers to stick in for consideration. Under moderate load the motors are limited to about 500 to 600 RPM with a microstepping drive and 40 volts. If you have a 10 TPI leadscrew you can do the math and come up with 50 to 60 ipm. There will be screams of protest but the RPM number I use is based on reliable operation (no lost steps, no motor stalls) and based on dozens of builds and hundreds of installs. The Acceleration being too high can cause a premature motor stall. 10 is not outrageous but may be too much for your setup.
The bottom line is the faster you spin a stepper motor the less torque you have. It a non-linear curve and drops off more rapidly at higher RPM. A motors RPM characteristics (torque dropoff curve VS RPM) are dependant on several factors (higher impedance motors tend to drop off faster even though they have the same low RPM torque).
The speed of a motor then becomes related more directly to the appled voltage. The current predicts the torque (and changes the torque curve mentioned above).
Just getting bigger motors may not yield a lot more speed because the RPM's won't be much more at the same voltage. You will get better low end performance and possible move the stall point up the curve some but not enough to double the speeds.
It's ususally not and issue with pulse frequency as long as you have MACH, EMC or an external pulse gen. At 25,000 pps and 10X microstepping you can get easily get 750 RPM (if your motor will give you that). Up it to 35,000 and have pulses to spare.
If you want more speed you have to get it down at motor RPMs' where the required torque is greater. That means a lower TPI count (like a 2 start thread) or a step up belt ratio or more volts to the motors (if your drives will handle it).
In a design you balance Speed VS torque and resolution. You have to pick one or the other with steppers. A lot of router builds are using 2 start (effective 5 TPI) or even 5 start leadscrews (effective 2 TPI) and larger motors to get rapids of 300 IPM or more and still have good torque and resolution at normal cut speeds for wood and light metals.
Dual drive gantries (motor on each side) gives you double the torque where you need it the most and eliminates mechanical loses from driving both sides with one motor.
TOM caudle
www.CandCNC.com
