Originally Posted by
sinha_nsit
Software operator's panel is very useful. I have used it to run the program in "Program Test Mode" which appears on the third page. The spindle does rotate, but the tool does not move. You can see the toolpath on the graphic screen. This way a program can be proved without bothering about a crash. Of course, if "Dynamic Graphic Display" option is available, then program test mode is not needed. A limitation of this mode is that correspondence between displayed and actual tool positions is lost. So, power cycle would be needed for actual machining.
