603,936 active members*
3,296 visitors online*
Results 1 to 17 of 17
    Jun 2004
    445
    Accuracy issues
    Hi there,
    My mill has been converted for quite a while now, but I am having trouble with accuracy. Today I was machining a small model engine part in an area of about 3 x 3cm. I set the zero point to the centre of a pre-drilled hole and then machined the part. The part included some holes that were meant to line up with holes on the engine's crankcase. After the part had been machined, the wall thickness of one side of the part was thicker than the other side, when they were meant to be the same. When I put the part onto the engine, all 4 of the mounting holes were offset to the right and down a bit. This is a bit irritating, as the 2mm holes are out by more than 0.5mm. I don't think it is inaccuracy in the leadscrew; 0.5mm over 3cm is ridiculous -I know my leadscrews are more accurate than that! I think it may somehow be accumulating an error. The reason why I say this, is because the features on the part that were machined first are close to the correct dimensions/positions, while the features that were machined later on are further out. You can almost tell what order everything was machined in just by looking at how inaccurate it's position is . It is offsetting everything in the same direction.
    All the code was hand-written, and I am confident that it has nothing to do with this, as the problem has occured on other parts too. I was using mostly G02 commands in the code. My machine is a Sieg X1 using the original leadscrews and TurboCNC for control.
    The leadscrews are meant to have a pitch of 2mm and that is what I have set it up to be on the software. If for whatever reason my leadscrews are not quite 2mm pitch, but the software thinks they are, can this cause an accumulative error?
    Does anyone have any idea what might be going on here? I need to sort this problem out, as having these slightly offset parts is worse than not having the part at all. It also gets irritating when you have to remake a part 3 times, just to find the third one is no better than the first...
    Warren
    Have a nice day...
    Mar 2006
    1625
    Start With A Dail Indicator With One Inch Travel Clamp A Block To Your Table Put .500 Load On Indicator Set A Zero On Controller Move The Axis .300 See If Controll Is Reading .300 Next Move The Axis Back To Zero If The Controller Is Back At Zero Then No Backlass In Manual Move Do The Same Thing With Program Moves See What Happen Then Do Th Same With Other Axis If You Don't Have An Indicator You Can Buy One For Short Money
    Dec 2005
    436
    chances are that your motors are skipping steps. I suggest re-running the program as a dry run. No material, no cutter, spindle off.
    Carefully observe the servo motor, look for odities in the revolutions in the motor output shaft.
    It is likely that the motor is being asled to work harder than it is capable of.
    Jun 2004
    445
    Hi there,
    I will see if I can get hold of a dial indicator and try that out.
    I don't think it is the motors skipping steps. The motors are 250ozin steppers which are already on the large side for this machine. I was machining with a 4mm endmill at a feedrate of 200mm/min in aluminium - if this is too taxing for it, then there is something badly wrong. I can't get the motors to skip steps by trying to stop the table either - it just ploughs on...
    Regards
    Warren
    Have a nice day...
    May 2005
    674
    Quote Originally Posted by itsme
    I take it from the fact that you don't own a dial indicator, that you never setup your machine correctly. Don't worry, it's easy, but you'll need some measuring tools. I'd highly recommend getting a test indicator (Brown & Sharpe BesTest or clone) and also another dial indicator on a magnetic stand.
    Use the test indicator to tram your head. Place the test indicator in the spindle using a good collet, angle it at about 45 degrees, and check to make sure that it gives you the same reading in each direction - North, East, South, West. I can almost guarantee you that i'll be off by quite a bit, at least in the East/West direction.... several thousandths.
    As for the dial indicator on the magnetic base, use that to do what lakeside suggested. You can also use it to measure spindle runout and quill accuracy.
    Mar 2006
    1625
    Brown and sharp stuff is very good and so is intrerapaded but cost take a look at spi and also craftsman you are not tiring to measure .0001 so why spend the money also e-bay is a go place to look
    Dec 2005
    165
    Hi Warren,
    Some thoughts:
    1) Yes of course if the leadscrew is not quite 2 mm pitch then this would lead to a scaling error if you input 2mm pitch.
    2) Did you input the screw pitch into the control software in metric or imperial. Your inaccuracy of 0.5mm in 3cm is the same as the inaccuracy in 1mm equals 0.040". Of course 1mm actually equals 0.0393701"
    3) You could use the machine to scribe a series of lines (using a pencil on paper) and check the error every inch over say 10" with a ruler. This will give you an idea of scaling errors.
    4) If you can't find the error in the hardware or your inputs to the software then you should talk with people on the Turbocnc forum (I assume there is one).
    Regards
    Phil
    Hi there,
    Warren
    Jun 2004
    445
    Hi there,
    I think it probably is time to get my machine setup and running properly. It gets extremely frustrating when parts don't turn out the way they should, because of a poor setup.
    I do have a dial indicator, but it only reads to 10mm, which I don't think is enough to setup the machine correctly. I had a look at dial test indicators too. There are a few details that I don't quite understand (since I've never used one of these before). They seem to have small dovetails that are used to mount them. How do you go about mounting the indicator into the machine spindle? Would I need to get hold of a matching dovetail holder that would go into a collet on my machine? Also, is the small 'needle' head the part that can be angled to, say 45 degrees?
    Warren
    Have a nice day...
    Mar 2006
    1625
    try this site for some attachment as far as set up keep the needle of the indicator at a slight angle to the surface that you are indicating?
    http://www1.mscdirect.com/CGI/N2SRHI?PMSECT=1321
    Nov 2004
    320
    Warren
    get yerself a plunger type dti (arc chronos) they have more travel
    maybe your lead screws are wearing
    mike
    Jun 2004
    445
    Hi Mike,
    I certainly hope my leadscrews aren't already worn out, as I only replaced the x-axis leadscrew about 1 week ago, when I added an extra length table to my machine. Just in case you are wondering, I did have similar accuracy issues before I replaced the leadscrew.
    I'm working on the DTI.
    Regards
    Warren
    Have a nice day...
    Dec 2005
    165
    Hi Warren,
    You have people spending their time trying to help you. It would have been useful if you had tried to help them help you by putting forward this extremely pertinent information at the start of your thread. Unless both leadscrews have the same systematic fault then you should be looking at the software.
    You work it out.
    Regards
    Phil
    Hi Mike,
    Regards
    Warren
    Jan 2005
    66
    I ran into this problem myself,, with a Sieg X2 I converted,,,and it turned out to be the gibs binding in one direction.
    May 2006
    5
    Did you ever figure out your problem?
    Jun 2004
    445
    Hi there,
    I did eventually figure out what was going on and it has now been fixed and everything is working properly.
    It turned out to be the power saving mode on the laptop that I was using. After 10 mins. the screen would turn off and at the same time, for some reason, it caused the machine to hesitate. The faster the feedrate at the time, the further out the axis would go. I found that when an axis was moving at over about 500mm/min, it would stop dead and make a horrible noise when the power save mode came in. This happened on all axes and in any direction of travel - it wasn't only in one direction as I originallly thought.
    The 'fix' simply involved turning off all power save modes on the laptop in the BIOS.
    Regards
    Warren
    Have a nice day...
    May 2006
    5
    You didn't notice this error when you were making your rotary engine parts? Glad to hear you got it sorted out though.
    Also, I seem to recall another member posting in your wankel thread to have a similar roundup error but his turned out to be a fault with his controller.
  17. #17
    Jun 2004
    445
    I was quite fortunate when I made the rotary engine parts, as I didn't have this problem. It had nothing to do with luck, but rather my setup at the time.
    When I made those parts, my mill was only running on 2 axes. I was operating the z-axis manually. Since each pass of the rotor or housing took less than 10 minutes, the power saving mode didn't have a chance to come on (since I was pushing buttons on the keyboard inbetween passes). I also wondered why the rotary parts had turned out without any issues before I actually knew what the problem was.
    I think that was Devin who had the problem with his controller. I'm not sure if he ever sorted that out.
    Regards
    Warren
    Have a nice day...
