603,870 active members*
2,894 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Acramatic 2100. NC ready signal on PLC output missing
    Sep 2010
    13
    Does someone know the criteria for the NC Ready from the PLC output to go high on an Acramatic 2100. To put it easier I have no NC ready signal to the CR5 relay. No alarms on the screen except emergency switch message, signal from this runs through the CR5 NC ready relay anyway
    Machine is an Cincinnati Lancer
    Feb 2007
    664
    check the for voltage at the emergency switch
    is this control pc based windows nt 4
    Sep 2010
    13
    Controller is pc based, yes. The emergency circuit last stop before the main safety relay is the CR5 relay I mentioned, 24 volt dc to the CR5 goes directly from the plc output on the controller, the emergency circuit can after what I understand not function before CR5 relay goes high.
    Thank you for answering
  1. Acramatic 2100 help!!
    By SBAGHAEI in forum Cincinnati CNC
    Last Post: 07-14-2016, 08:28 PM
  2. Acramatic 2100
    By dmerrll in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2012, 10:41 AM
  3. Acramatic 2100
    By clayman in forum MetalWork Discussion
    Last Post: 02-19-2011, 12:29 AM
  4. Acramatic 2100 G83
    By cnccalgary in forum MetalWork Discussion
    Last Post: 03-11-2009, 04:03 PM
  5. Acramatic 2100 hdd
    By Amtec in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-18-2009, 08:49 PM
