587,768 active members*
3,798 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Acrylic vs. SAN for mill enclosure
Results 1 to 6 of 6
    I'm going to build an enclosure for my mill.
    The window materials available localy are Acrylic (Plexiglas) and SAN (styrene acrylonitrile).
    Does anyone know which of these materials are likely to last longer in this application? I'm a bit worried about how long they will remain clear and structurally sound when sprayed with coolant and chips.
    Feb 2006
    7063
    Re: Acrylic vs. SAN for mill enclosure
    It's going to depend in part on exactly what coolant you use....
    Regards,
    Ray L.
    Quote Originally Posted by SCzEngrgGroup View Post
    I use Koolmist 77 in a fog-less mist cooler. I'm also considering using the same coolant for flood cooling.
    Feb 2006
    7063
    KoolMist and acrylic are fine. But, you should know, KoolMist is lousy for flood unless all you're doing is very light milling. It is strictly a coolant, and provides NO lubricity, so it is worse than useless for more difficult operations that require lubrication, like drilling.
    Regards,
    Ray L.
    Jun 2007
    47
    Acrylic has glass-like properties, including poor impact resistance. You might want to look into polycarbonate as an option. If you're in the US getting it delivered is easy.
    Dec 2013
    290
    Polycarbonate (lexan) is the only material I would consider for a machine.
    Work: Hurco VMX42/VMX50 - Shopsabre 4896 - Bobcad V4 4axis pro
    Home: RF45 with Ajax CNC Controller - Bobcad V27 3 axis pro
  1. X2 mini mill & enclosure
    By QSPSB in forum Benchtop Machines
    Last Post: 08-27-2010, 10:35 PM
  2. Looking for a mill enclosure
    By adryan in forum Vertical Mill, Lathe Project Log
    Last Post: 11-20-2007, 08:07 AM
  3. DIY Mill Enclosure
    By ixen.yeo in forum Benchtop Machines
    Last Post: 11-01-2007, 04:59 AM
  4. CNC Mill for acrylic.
    By MrArmyAnt in forum DIY CNC Router Table Machines
    Last Post: 09-11-2005, 03:58 PM
  5. CNC Mill for acrylic.
    By MrArmyAnt in forum Open Source CNC Machine Designs
