I picked up a new 3 axis Anorad D-serv servo controller about 2 years ago. Paid $50 for it at a surplus store. Think it was a spare for a piece of semiconductor equipment. Anyway...
Few months ago I called Anorad to find out what I could about it since I dont have any of the manuals for this critter. Normally they would have charged me $100 for the manuals but the tech went ahead and emailed them to me. Looin gthrough the manuals I found this is actually made by ACS Tech80 (
http://www.acs-tech80.com). I was able to get the setup software from their site.
This controller seems to be amazing. Runs off of 115v and supports 3 axis' at 6.5A cont each. It will run DC Brushless (AC Synchronous), AC induction motors, DC Brush Motors, two phase steppers at 256 microstep, and three phase steppers. Each axis is indivdual and you can mix motor types. Also you can use it as a VFD to run high speed 3 phase mill spindles up to 3000 hz for a max 180000 RPM. Whoa!
By hooking it to standard three phase induction motors and adding a shaft encoder for feedback you can run these as cheap high performance (Although high inertia) servo motors.
It can accept serial (rs-232/422) input as well has two analog inputs per axis plus 1 analog output per axix, plus dedicated digital IOs for each axis and estop functions.
Needless to say I would love to use this controller on my CNC gantry project. I just dont know how I can interface to it. It uses a language called ACSPL through the serial port. It can also be configured to accept joystick input via the analog inputs. Also it has some sort of master/slave control that sounds promising.
Anyone work with these kind of controllers?
-Jerry
