603,960 active members*
3,449 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > ACS806 and ACM604V60-01-1000 tuning
Hybrid View
Mud_ ACS806 and ACM604V60-01-1000... 05-17-2022, 06:50 PM
Mud_ Re: ACS806 and... 05-17-2022, 07:23 PM
    Oct 2017
    21
    Hi, I have the ACS806 (V2) driver and ACM604V60-01-1000 servo motor (well, 4 pairs...), and I'm struggling to get started. The current tuning response dips below the purple line (negative current?), whilst the manual makes it look like it should return to the purple line. Any attempt at motion is violently jerky and trips the over-current. See attached for current trace.
    There are certain configuration values (inductance, inertia, resistance, etc.) the software won't let me set - I'm not sure if that's related. I have set rated current, motor pole pairs, encoder lines and position following limit at least.
    Oct 2017
    21
    Re: ACS806 and ACM604V60-01-1000 tuning
    Further plot, showing what happens if I try the position loop, even with very low values.
  1. Replies: 1
    Last Post: 03-25-2019, 07:21 PM
  2. Replies: 1
    Last Post: 07-23-2017, 08:47 PM
  3. Problem with driver ACS806
    By thachdovan in forum Leadshine
    Last Post: 12-26-2016, 06:06 AM
  4. Haas HPC-1000/TSC-1000 coolant pump, like new!
    By stuntjake912 in forum For Sale Only
    Last Post: 03-14-2016, 03:05 PM
  5. Leadshine ACS806 AC servo ...smoked !
    By Larken in forum Leadshine
    Last Post: 08-15-2014, 03:31 AM
