587,779 active members*
2,935 visitors online*
    Jan 2008
    77
    Acu-rite Glass Scale Position
    Has anyone used an Acu-Rite glass scale with the Position-Trac feature as a an absolute reference? Position-Trac encodes the absolute position of the axis into the reference output. Rather than a single pulse at the center of the scale, it has the absolute position encoded on the reference track so that upon powerup, the current position is known. I want to know how it is coded on the scale and how to use it.
    I couldn't find anything at the Acu-Rite site. Tech support did not know.
    Mar 2011
    67
    There are staggered sets of reference marks something like every 50mm. The distance between each ones is a little larger (or smaller, depending on which way you are moving), so that when it crosses any pair anywhere, it does a little math and figures out where it is. There is usually a short 'set-up' procedure to find a pair of marks, then you can use them to 'preset' a home position. After the next power cycle, you cross them by moving ~50mm in either direction, then it re-establishes your preset home position again.
  1. Blacklash with glass scale Heidenhain
    By tapinlu in forum Uncategorised MetalWorking Machines
    Last Post: 04-19-2015, 05:16 AM
  2. Using an Acu-Rite scale on a Grizzly DRO???
    By ranchak in forum CNC Machine Related Electronics
    Last Post: 09-15-2008, 12:19 AM
  3. DIY Adaptor for Acu-Rite glass scales?..
    By hotponyshoes in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2008, 01:32 PM
  4. anyone have futaba glass scale?
    By fastolds in forum DNC Problems and Solutions
    Last Post: 03-03-2006, 04:34 AM
