Hello,
For those of you that use the adaptive rough toolpaths, are there big difference's between the one provided in V26 vs V28?
Admittedly, I have not really used any of the adaptive toolpaths in my V26 as I really haven't had a machine that could handle the code (up till recently have been using a 32 year old Mazak), however, I recently installed a much newer machine that can handle the look ahead and feedrates to a much better extent. It also has enough memory to handle most 3D programs I may encounter.
I did make a quick 2D program a few days ago and everything seemed to work well, although I was just cutting air. Hoping to make some test cuts today or tomorrow. I seem to remember reading a thread from a few months back that described an issue with the spiral lead in on these paths but can't remember the details, or even if it was in V26 or V28. My test program starts off the part. I have not tried a test part with an enclosed pocket yet.
Been awhile since I've upgraded so thinking now may be the time.
