587,786 active members*
2,570 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Adaptor for 1/8" bit in 1/4" inch router bore
Results 1 to 20 of 20
    Oct 2005
    2392
    Hi, does anyone know where to buy an adaptor to fit 1/8" tools (like Dremel bits etc) in my 1/4" router??
    Thanks.
    Jul 2006
    141
    Adapters
    I just purchased a set from K2cnc on e-bay, Very satisfied with product.
    http://cgi.ebay.ca/K2-CNC-Router-1-8...item5885ec99f9
    GG
    Mar 2008
    177
    Oct 2005
    2392
    Thanks grinder_gary but I don't think that simple grub screw collet from ebay will do, I was measuring my Dremel bit shanks with the micrometer and the shank diameter ranged from 3.05mm on some bits to over 3.3mm on others.
    EBC- I looked at the collets in your link, that looks more like what I am after but I'm not sure which one will suit my router shaft. My router collet is straight for about 2/3 of the length and then has a tapered area on the front third. Unfortunately the precise bits web site doesn't show dimensions, angles or any drawings for me to compare.
    If anyone has more info or more suggestions I would appreciate it. I've been considering buying a $30 hardware store Dremel copy and cutting the shaft out and turning it down to 1/4", then I would be able to use the small collet range that comes with it.
    Alternatively if I can get more info on the nice ER style collets on preceisebit.com website then maybe one of their range will fit straight in my router.
    Mar 2008
    177
    Question
    www.use-enco.com
    Lots of stuff here...might take a while to find what you need:cheers:
    Gene Crain
    www.plantasymaderas.com
    Oct 2005
    2392
    I can't find any adaptors in that enco site, apart from the usual (high priced) proper collets for milling and stuff.
    I thought this would have been a commonly sought after item, some way of putting 1/8" shank bits in a 1/4" bore router??
    Jan 2005
    150
    Do you have any idea what the specs should be for the collet you're seeking? If they match what I have, I'll just turn a few extra for you guys. No big deal.
    Feb 2009
    2143
    Oct 2007
    97
    Quote Originally Posted by RomanLini View Post
    What kind of router are you using? If this is a custom piece, what is your taper angle?
    John Torrez
    Think & Tinker / PreciseBits
    Jan 2005
    150
    Here's what I did... Grabbed some 316 sst, wrote a quick turning program, and machined an adapter to convert my .250 router chuck to hold .1875 tooling. All I need to do now is to machine a slot with a slitting saw on one side and then it should work like a charm. Picture follows...
    I don't see why this simple, yet economical solution wouldn't work on any brand of .250 collet chuck. Now my question is... 'Does anybody want these if I made a batch of them'? and 'What should I charge for these collets, less shipping'? And lastly, is there any real demand for these 0.1875 collets or the smaller 0.125 collets?
    Oct 2005
    2392
    mcphil- that little Dremel chuck adaptor looks great and I can see me getting one in the near future, mainly for PCB drilling and some special tasks. But for engraving and machining (especially in soft plastics) I am not sure if the rigidity or runout would be up to my requirements.
    SanDiegoCNC- Wow that's really nice to offer to make something, I'm new to the community here so that was kindof a surprise and of course if you do end up making something custom for me I would be happy to pay. I've already made something similar here out of a 1/4" stainless rod stock, I drilled it on the lathe and then cut a split down one side. But that has problems, one is that I am not a machinist I'm an electronics guy, my lathe has about 0.0004 runout and all I could do to bore it 1/8" was a drill bit.
    Of course there are other issues that the single split causes more runout and my Dremel bit shanks measure 3.05mm to 3.30mm which poses more problems.
    TDA- thanks its nice to hear from precisebits! My router is an australian brand Ozito, it has superb runout and a 42mm metal clamp outer surface so it is great for my little machine. But i don't know much about the collet specs or standards. Here are some rough measurements;
    length 20.3mm
    taper on the front 5.5mm length
    3 splits, from the front
    front and rear surfaces are flat
    bore 1/4"
    rear diameter 10.0mm
    front (where it is the widest) diameter 12.3mm
    taper angle measured with crude protractor seems about 12' each side, might be 15' it definitely seems larger than 10'.
    I can post pictures if you want.
    Oct 2007
    97
    Quote Originally Posted by SanDiegoCNC View Post
    The general problem with this type of setup is runout. Even if your adapter is perfect (something even ER collets can't manage). You still have to deal with the runout in both the collet and the router. I have seen new stock collets runout vary from .0004-.006. Obviously some manufacturers are better then others but with most you are rolling the dice when it comes to collets.
    Why does runout matter so much? When you are dealing with larger tooling runout isn't as much of a problem (although it does effect tool life and kerf width). However, when you are talking about 1/8" shank tooling it can be a big problem. A good rule of thumb is 10% of the diameter of a cutter in runout will break the tool. Currently our most popular sizes are probably .0156", .0200", .0230", and .0313". So when you are talking about even a .0313" cutter that only gives you .003" of runout. If your stock collet is over that then you will break that sucker right off.
    One last note. I somewhat known for being a downer so let me try and make this clear. I'm not trying to discourage you. I'm just trying to pass along what we have found over the years.
    length 20.3mm
    bore 1/4"
    If you could post some pictures it might help. I have had a hard time finding any online.
    John Torrez
    Jan 2006
    2985
    Oct 2005
    2392
    keebler303- I've already made a single split tubular adaptor, I have 1/4" ground stainless rod here so I just drilled in in the lathe and cut a slit in with a grinding disc. It's ok but not a good solution for 1/8" shanks that vary from 3.05mm to 3.30mm like some of mine do.
    TDA- I appreciate your continuing help. I'll dig out the camera later and post some pics. My 1/4" router taper and collet are excellent, less than 0.0002 (in that "wobbly" undefined range of my dial gauge).
    My goal is to leave the 1/4" router permanently installed in the machine for fast machining jobs, then just use a 1/8" adaptor for when I need to do fine work like lettering engraving, PCB engraving etc. I've already lathed up a workable split tube adaptor but in the longer term its seems worth investing in one or more good adaptors.
    Photos coming soon.
    Oct 2007
    97
    Keep in mind when you are in that ""wobbly" undefined range" all you know is that it's less then one unit of your indicator. We discovered this when we went from a .0005" indicator to a .0001" indicator. Half of a .0005" tick could be .0001" or .0004" when measured with our .0001" indicator.
    John Torrez
    Oct 2005
    2392
    Hi again, here's the photo of the collet and nut.
    You can also see the first split tube adaptor I made up, the split looks nasty because it was done with the angle grinder but the outer is 1/4" stainless ground rod and the inner 1/8" bore was drilled on my 7x20 lathe after checking runout. If I make another it will look nicer.
    Anyway, does the collet/nut look familiar? It would be great if you had a screw-in solution.
  17. #17
    Oct 2005
    2392
    Any updates? Would any of your precisebits collets work in my router? That is assuming you can tell the collet style from my photo.
    From looking at some internet photos I think one of the Colt brand routers uses a very similar collet to mine.
  18. #18
    Oct 2007
    97
    Sorry about the delay. I did not get a email update for your previous post which I rely on when we are busy here.
    Anyway, we do not currently carry a collet that even looks like that. It almost looks like a Shoda or Perske style but I don't think either of them would work. I wish I at least knew of somewhere to point you, but unfortunately I don't.
    If there is anything else I can do please let me know.
    John Torrez
  19. #19
    Oct 2005
    2392
    Thank you TDA I appreciate your help with this, and everyone's help actually.
    If I get any more information I'll post it here.
  20. #20
    Jan 2006
    23
    Some of the newer high speed mills are using a heat shrink type tool holders. You could do the same with your adapter. Start with the 1/4" stock and drill the hole slightly smaller than the 1/8" bit. (about .0005) heat up the adapter and press the bit into the adapter. It shouldn't move on you. I've also had luck using locktite to "glue in" a cutter in a similar setup. With out the slot there will be less run out.
    J.
  1. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
    By Modular CNC in forum Open Source CNC Machine Designs
    Last Post: 11-25-2013, 12:57 PM
  2. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  3. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
  4. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
  5. Boss 6 Motor Pulley Options - 5/8" to 1/2" Bore
    By snakebit95 in forum Bridgeport / Hardinge Mills
    Last Post: 08-11-2006, 08:03 PM
