603,979 active members*
1,364 visitors online*
    Apr 2003
    1079
    Adding 3rd axis/live tooling to lathe
    Hiya guys, just wondering if anyone has added indexing to their lathe spindle? Should be easy enough to control it, just need a method of dis-engaging the servo motor when I want to run in normal lathe mode.
    Obviously I will need live tooling to go with this idea, so has anyone built a milling attatchment designed for turning? I guess this would be programmed the same as a rotary axis on the mill eh?
    Dec 2003
    24260
    If you put a servo/stepper on the spindle it could be engaged by a simple DC clutch, and the control would be a 360deg indexer. Every time you engage it, you would have to reference it first.
    Al
    Albert E.
  1. Mini Lathe Tooling plate
    By JFettig in forum Mini Lathe
    Last Post: 08-10-2005, 05:14 AM
  2. Help me buy my first Mini Lathe
    By Highfly in forum Mini Lathe
    Last Post: 05-10-2005, 08:07 AM
  3. OneCNC XR Series Lathe CAD/CAM Released:
    By OneCNC in forum News Announcements
    Last Post: 03-07-2005, 11:20 PM
  4. adding cnc to lathe (which one)
    By mark c in forum Mini Lathe
    Last Post: 03-04-2005, 02:39 AM
  5. Just got a taig lathe.
    By anoel in forum Mini Lathe
    Last Post: 01-18-2005, 11:29 AM
