603,893 active members*
4,091 visitors online*
Results 1 to 5 of 5
    Aug 2014
    7
    Adding 4th axis
    I am thinking of adding a 4th axis on my homemade cnc machine to turn my workpiece radially. My controller only has 3 ports. I'm wondering if I can disconnect either my x or y axis stepper motor from the controller and then use that free port to run a spare motor which will be set up in the mach 3 sw using the A axis. Since the A axis will turn the workpiece radially, I only need to move the router on the Z axis and in one other direction...either X or Y. Wondering if anyone has successful tried doing this.
    Dec 2007
    2133
    Re: Adding 4th axis
    That's exactly how a lot of the Chinese CNC machines are configured, usually the X axis is moved to the rotary axis. On my 6090 this is how it's configured so the rotary axis is placed longways along the Y Axis and the X controls the rotary moves.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Aug 2014
    7
    Re: Adding 4th axis
    Thanks Ian
    I'll go on the assumption then that my idea will work for my setup. I'll get myself a spare stepper motor and go from there
    Charlie
    Dec 2007
    2133
    Re: Adding 4th axis
    If you do that, it's important to match the rotary stepper to the X or Y axis your connecting it to, otherwise you'll need to reconfigure the stepper settings everytime you use it. It's a little thing, but it can get annoying, especially as you'll likely need to calibrate each time too then.
    cheers, Ian
    Apr 2004
    5951
    Re: Adding 4th axis
    If you do this, remember that you'll have to provide a brake of some kind for the axis that isn't being used, since the stepper won't be energized and keeping the axis from back-driving itself out of position.
    Andrew Werby
    Website
  1. Replies: 1
    Last Post: 03-18-2015, 03:35 AM
  2. Adding 4th axis (rotary) to a 3 axis cnc router
    By Azalin in forum DIY CNC Router Table Machines
    Last Post: 03-05-2015, 09:50 AM
  3. Adding a 4th axis to a VMC 40?
    By Waynno in forum Fadal
    Last Post: 04-29-2011, 03:03 PM
  4. Replies: 0
    Last Post: 05-28-2008, 04:37 PM
  5. adding 4th&5th axis
    By cnc prog in forum Daewoo/Doosan
    Last Post: 09-25-2006, 10:26 AM
