603,897 active members*
3,483 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > adding a 4th axis.....
Results 1 to 8 of 8
    May 2020
    14
    Hi all
    I've got a new hurco vm5i on the way, do I need to use all hurco parts? anyone fitted a 4th to a newer hurco?
    Jun 2008
    1111
    Re: adding a 4th axis.....
    I fitted a Kitagawa table to a VM5i. Are you considering putting it on a subtable so the 4th is outside the work envelope?
    May 2020
    14
    Quote Originally Posted by bloke View Post
    which did you fit?
    Yes, given there's almost 12" of space, I'd like to fix subtable in place and have the 4th occupying that area. have you got a vm5i or just fit them?
    Thanks for the reply.
    Jun 2008
    1111
    I work for Hurco in the UK. It was a small 100mm dia Kitagawa (I can’t remember the model number off the top of my head but I could find the parameter sheets I wrote up for it and find out from there).
    The biggest pain in the butt was finding a place to put the Servopack.
    May 2020
    14
    that would be amazing. I've been told a 160/200 fit also. Seems a minefield.
    May 2020
    14
    machine is in....a bit tight...
    Nov 2019
    9
    Bloke, Can I get your email address, I have a couple of questions for the Hurco BMC 30
    Jun 2008
    1111
    What BMC30?
