603,964 active members*
1,999 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Adding a 4th Axis to a 97 BMC 30 M
Results 1 to 10 of 10
    Sep 2006
    74
    Anyone ever add a 4th axis to a 97 BMC 30M ? The controller allows for 5 axis, but I believe I need to add on quite a bit to the Siemens system to get there.... anyone, anyone ?
    Sep 2012
    Can you give any information about hardware on your Hurco and which 4th axis do you wanna put up??
    Jun 2008
    1111
    You'll need to add a DSP card, a DCI/O card, a small selection of ribbon cables, a Honda breakout board, Internal wiring to the outside of the cabinet to connect the rotary to, a servo amp to suit the motor in the table, a suitable set of parameters for the control and servo amp and an air/hydraulic supply to suit whatever brake the table uses.
    Sep 2006
    74
    adding 4th axis
    The unit has an Ultimax 3 w/ A and B axis capability, Siemens Simodrive 611 control system, and the wiring harness is there for the external mount. I think this isn't a plug and play setup for sure, but if I get a 4th and 5th axis setup of hardware, I won't sleep until it runs smoothly. I have built smaller systems, and worked as an app engineer, so I'm not flying blind. I just wondered if anyone had done this as a retrofit....
    Jun 2008
    1111
    This far from it's original build, it'll be hellishly expensive. If it's got it's original CPU (Pentium motherboard instead of a passive backplane type) and you can't get a DSP with the same firmware as your existing one, you'll need to upgrade to:
    Peak715 or Peak777 Cpu.
    Passive backplane.
    Uprated power supply.
    XMP card.
    2 x RMB modules.
    Servo amp to suit.
    Cabling to suit.
    DCI/O card.
    V2.37 software.
    That isn't going to be a cheap option.
    Sep 2012
    If your Hurco is prepaired for 4th and 5th axis, then you should have DSP board prepaired and no extra costs. Naturally, its never plug and play and every time, every machine, is different. Did you buy 4th axis and which, if you have?
    Sep 2006
    74
    Looking at this one : Hurco 4th Axis CNC Indexer | eBay
    Feb 2009
    6028
    That indexer won't work as is I don't think. Yaskawa motor type, would have been for a yaskawa drive hurco.
    Jun 2008
    1111
    If it only comes with what is in the ad, it will need a significant amount of extra stuff. It looks as if he's left the cabinet interface parts with the machine. If he is selling along with the cabinet parts, it'll be a good deal. There wouldn't be a problem fitting it if it's all there.
    Sep 2006
    74
    Thanks Bloke, I will email the guy to see..... Cheers
  1. Adding an AXIS
    By Bohemund in forum CamSoft Products
    Last Post: 08-26-2011, 04:17 PM
  2. Adding a 4th axis to a VMC 40?
    By Waynno in forum Fadal
    Last Post: 04-29-2011, 03:03 PM
  3. Replies: 0
    Last Post: 05-28-2008, 04:37 PM
  4. Adding 4th axis
    By bgmnn in forum HURCO
    Last Post: 05-23-2008, 04:56 PM
  5. Adding A 4th Axis
    By helix77 in forum EdgeCam
    Last Post: 04-13-2006, 08:36 PM
