603,979 active members*
1,316 visitors online*
    Jun 2006
    17
    adding camsoft control to an omniturn
    We've got an omniturn gangtool lathe.The machine runs great and is very accurate.The one thing I cant stand is the control-it's dos-based and has no macros and very limited cycles.I've been looking at different software and camsoft looks to be the best fit.My question is this: Is it possible and if so how difficult would it be to keep all the same motors,connections, etc. and just replace the omniturn control(monitor,computer,keyboard, and operator panel) with a camsoft package? Are there components that would have to be replaced because of different connector types etc?CNC control/machine interface I know next to nothing about-Please tell me as much as you can.
    ACE
    Apr 2005
    51
    Mr ACE
    I say yes. I keep my customers motors and drives. It was very expensive to change drives for him and much work for me that I did not want to do. Camsoft is best for keeping the original equipment. They have good tech support that will help you do this to you do not know how. They will send someone to you if you ask to help. I think you do not need the same connector. The connector I used has screw down terminal screws that were easy to connect my wires. Ask the tech man ruben for a wiring chart on your motors.
    Carlo
    Mar 2004
    1527
    Financially, I think you'd be better off selling your Omniturn, they have decent value.
    Start with something like this
    http://tinyurl.com/2mg8v2 for your Camsoft machine.
    or, if you'd like a turret, get a hardinge CHNC. These machines are common, the steel is excellent and the controls are obsolete.
    I'm not sure, but I'd expect some hidden gotchas trying to use Omniturn components on a camsoft refit.
    P.S. I have a wonderful Camsoft CHNC
    Karl
  1. Adding a fan to the X3
    By Antonyong in forum Benchtop Machines
    Last Post: 04-26-2007, 05:19 AM
  2. Camsoft control issues
    By HANSENTECH in forum CamSoft Products
    Last Post: 03-25-2007, 03:12 PM
  3. Need Dimensions of Omniturn Tooling Plate
    By lerman in forum Mechanical Calculations/Engineering Design
    Last Post: 03-07-2007, 06:58 PM
  4. adding 4th&5th axis
    By cnc prog in forum Daewoo/Doosan
    Last Post: 09-25-2006, 10:26 AM
  5. Adding a 4th
    By Shizzlemah in forum Fadal
    Last Post: 12-02-2005, 12:16 AM
