603,409 active members*
3,349 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > Adding a manual gear change call
Results 1 to 6 of 6
    Jul 2004
    93
    Yes i am trying to add a call for a manual gear change to my
    centriod post mc8. something like an if statment.
    If speed is < than 2500 post comment
    "M0 (CHANGE TO LOW GEAR)"
    IF speed is > than 2500 post comment
    " M0(CHANGE TO HIGH GEAR)"
    I am runnuing a BP series 2 with inverter and a manual switch to change from high to low which changes the spindle direction ,but would like a statement with a M0 to make the changes
    Thanks Brad
    IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH
    Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust.
    Dec 2003
    24260
    If your conditional statements (if speed etc) work on the Centroid (or should it be 'if S' ?) and anything between the " " is a comment then I would say that the M0 has to be outside of the comment string to work.
    Al
    Albert E.
    Jul 2004
    93
    Al thats what i dont know how to write
    it should work ,and I can put the M0 just before after it?
    this is the post ihave been messing with
    *progno, e
    "(PROGRAM NAME - ", progname, ")", e
    "(DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, ")", e
    psof0 # Start of file for tool zero
    psof
    psof # Start of file for non-zero tool number
    pinit
    !opcode
    n, "G17 G40 ; Setup for XY plane, no cutter comp,"
    n, "G20 ; inch measurements"
    n, "G80 ; cancel canned cycles,"
    n, "G90 ; absolute positioning,"
    n, "M25 G49 ; Goto Z home, cancel tool length offset"
    n, pinc, *sg28ref, "X0.", "Y0.", e
    n, "M0"
    n, *t, "(CHANGE TOOL)"
    ptoolcomment
    pcomment
    n, "(CHECK GEAR)" would like to put the if statment here
    n, speed, *spdlon
    pcan
    pcan1, n, pasb, "G00", pwcs, *xr, *yr, strcantext
    pcan2
    n, ptllncomp, *zr
    pcoolon
    any ideas?
    Dec 2004
    44
    pcomment
    if speed <= 2500, n, "M0 (CHANGE TO LOW GEAR)", e
    if speed > 2500, n, " M0(CHANGE TO HIGH GEAR)", e
    n, speed, *spdlon
    I think if you add 2 lines it will work as you wish
    Nov 2004
    21
    I think what you want to do to compare the next spindle speed with the current spindle speed and if a high/low range is required, then output your M0 and comment. Otherwise you are going to get a "spindle speed high/low" at each speed change when you don't require a range-change.
    Mar 2004
    21
    Put this in ptlchg before the spindle output
    "Tested in version 9"
    if speed >= 2500,
    if prv_speed < 2500, "M00", "(CHANGE TO HIGH GEAR)", E
    if speed < 2500,
    if prv_speed > 2500, "M00", "(CHANGE TO LOW GEAR)", E
  1. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum Uncategorised CAM Discussion
    Last Post: 04-05-2012, 03:55 PM
  2. Manual Automatic Tool Change
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 09-29-2004, 06:21 PM
  3. Metric Change Gear Combinations by J.W. Early Excel Spreadsheet
    By cncadmin in forum DNC Problems and Solutions
    Last Post: 05-26-2003, 09:17 PM
